Graphics 3 monitors
Discussion in 'Hardware' started by Pookeyhead, 11 Aug 2010.
  1. Pookeyhead
    30 Jan 2004
    Is there a nvidia equivalent to eyefinity? What's the nvidia solution to 3 monitors?
    Will games designed for eyefinity like Dirt2 play nice with any nvidia solution?
    Only recently getting interested in this multi-monitor malarkey, so I'm a dry sponge craving info to soak up :)
  2. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    nVidia have a system in place that supports up to 8 monitors using SLI, called Mosaic. Problem is, currently it's a Quadro exclusive architecture. You can bet your ass that nVidia are working on bringing it to their GeForce GPUs though.
    Also, there was this at the beginning of the year.
  3. Pookeyhead
    30 Jan 2004
    Doesn't the 3d thing need 120Hz screens though?
  4. Phalanx
    28 Apr 2010
    That is true. Noone said it was perfect. I would wait a while and see if nVidia bring Mosaic to the GeForce range.
  5. Pookeyhead
    30 Jan 2004
    I shall watch what happens. Whatever I do, it won't be for a while.
  6. Ternix
    Ternix What's a Dremel?
    5 Nov 2009
    Of course there is always the option of Triple Head 2 Go. It's an external unit and supports up to 3x 1680 x 1050. Buy 2 of them and can have upto 6 monitors. Advantage of TH2G is you can use any card with it. Of course it costs as much as the card but you don't need any special monitors to use it.
    http://www.matrox.com/graphics/en/products/gxm/th2go/
  7. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    you are limited with resolutions with TH2Go - it uses a dual link DVI which can only provide for 3x(1650x1050) i believe.
  8. Teelzebub
    27 Nov 2009
  9. Xonar
    Xonar What's a Dremel?
    2 Nov 2009
    The Nvidia cards are capable of there own 'eyefinity' solution using 3 monitors with or without utilising 3D, the only difference between the 2 is that ATI can manage to output 3 screens using a single card where as Nvidia requires 2 in SLI at a minimum (or a single GTX 295).
  10. Pookeyhead
    30 Jan 2004
    I'd need at least 2 1200x1600 (portrait 4:3) and 1 2560x1600 screen, possibly 3 2560x1600. So that rules TH2Go.
  11. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
  12. Pookeyhead
    30 Jan 2004
    The guy in that thread has 3 cards. You sure you need only 2?
    I have a GTX295. Does that count? Technically it's SLI.
  13. Xonar
    2 Nov 2009
    Ye you're definitely ok with two unless you have a dual GPU card such as the GTX 295 which will allow you to run it all from a single card.
  14. barndoor101
    25 Oct 2009
    in any case, dont both solutions require all 3 monitors to run the same resolution?
  15. Delphium
    18 Mar 2007
    Indeed that guy does have 3, but it requires a minimal of 2 cards but works with TRI-SLI also ;)
    Or of cause the gtx295 dual slot version... the single slot version only has 2 phyical outputs on the card anyways.
    Yes the monitors need to be the same resolution... or rather, any larger res screens will simply run at the max of the smallest resolution monitor.
    Example if you had...
    1920x1080 + 1680x1050 + 1920x1080 then all monitors would run at 1680x1050 each.
