Modding 3 or 5V led?
Discussion in 'Modding' started by cgsimons_2000@yaho, 1 Mar 2004.
  1. cgsimons_2000@yaho
    cgsimons_2000@yaho What's a Dremel?
    12 Jan 2004
    Parameter Min Typ Max Unit
    Luminous Intensity 4308 5600 6200 mcd
    Viewing Angle ~ 30 ~ Deg
    PeakEmission Wavelength ~ 515 ~ nm
    Forward Voltage ~ 3.6 4.5 V
    Reverse Voltage ~ 5 ~ V
    Forward Current ~ 20 ~ mA
    Reverse Current ~ ~ 100 uA
    Operating Temperature Range -25°C to +80°C
    Storage Temperature Range -40°C to +80°C
    Lead Soldering Temperature (4mm from body) 260°C for 5 seconds
    Color
    Link to LED http://www.lsdiodes.com/5mm/
    The 5 mm green led - 6200mcd
    Will this be qualiyied as a 3 or 5 V led?
    Im going to have 4 leds in serie, 4*3 V = 12V
    So I can connect it directly to the 12V from the PSU.
    Will this work?
    Ill need a switch somewhere to to turn on/off
  2. kt3946
    kt3946 What's a Dremel?
    17 Feb 2004
    First off, 4 LEDs in series will require more than 12v. This is because the forward voltage requirement is 3.6v, NOT 3v. That results in a series voltage requirement of: 3.6v*4=14.4v
    You may also want to check this thread:
    http://forums.bit-tech.net/showthread.php?p=542414
    There I posted a link to a nice calculator for series LEDs that will help you figure out all the values you need.
    If you want to drive these off of a 12v power line, then you would be best served by using a series/parallel combination, or strictly parallel. However, be careful as the series resistance necessary to minimize the forward current will be different than the necessary parallel resistance.
  3. cgsimons_2000@yaho
    12 Jan 2004
    Red led
    forward voltage 1.7
    Forward current 20Ma
    12V molex
    Switch on/off
    In series 4 leds of 1.7 V and 20Ma
    and at the end a 270 Ohm resistor.
    0V molex
    Is this a right setup?
  4. kt3946
    17 Feb 2004
    As long as you use the 12v line, that should work fine.
  5. cgsimons_2000@yaho
    12 Jan 2004
    A new question
    If I want to change the colour on the power led, to blue... how?
    How many volt are the Mainboard giving?
    The same question for the acticit led to
