Electronics 3-Pin Fan Plugs - SHORT Question.
Discussion in 'Modding' started by PureSilver, 8 Apr 2009.
  1. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Am looking to splice connectors into all 5 of my case fans and all 5 temperature probes so I can pull the controller without having to de-stick all the probes and rummage in hard-to-reach corners of my case. The logical connectors, I thought, would be standard 3-pin fan plugs for the fans, and maybe for the probes too (though they're only 2-wire), since then I don't have to cut any cables on the bus and can just use them as a sort of extension cable.
    This was logical until I realised that I have no idea where to find such things as just the plugs. Neither Maplin nor RS seem to be much use. Why can't you just buy a bag of them? Aren't they hand-solder-able, or what?
    If you know where to get hold of such things, or indeed ANY easy to solder small 3-cable connections - let me know! Do NOT want to have to stick a #$%£ing terminal block in my pride and joy... :dremel:
  2. talladega
    talladega I'm Squidward
    18 Aug 2007
  3. Cheapskate
    13 May 2007
    Futurlec has them much cheaper. They won't charge $10 for shipping either.
    Direct link
    It will take forever to get the stuff. They ship directly from Thailand.
  4. ch424
    ch424 Design Warrior
    26 May 2004
    Is Farnell of any use? They do free delivery! Note that some of the pictures are wrong and some of the ones that are pictured as 5-way are actually 3-way!
    Edit: this one doesn't have tabs on it, but would probably work, and looks easy to solder!
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    With a large minimum order. :sigh:
    Futurlec are 10-14 days to the UK IIRC but cheap delivery and zero VAT to pay.:thumb:
    btw, Maplin sell them, as do Rapid. Just look for 0.1" PCB connectors. Not all that easy to solder wires to the male part; another idea is 3.5mm stereo jack pairs.
  6. ch424
    26 May 2004
    Nooooooo! When did they change that? I once bought £1.10 of PCB buttons and the UPS guy came the next day for free!
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Trade account customers have always been free but "The minimum order value for non-account credit or debit card customers is £20" is what I found for Useful Links a year or so back. Can't find anything about "non-account credit or debit card customers" in the latest T&C (March 2009)
  8. ch424
    26 May 2004
    Aha! It's still free for me though because I'm a freeloading student! (onecall.farnell.com) :p
  9. PureSilver
    16 Dec 2008
    I... wow. Thanks, everyone, those look very promising!
