Cooling 3 ports, why?
Discussion in 'Hardware' started by Headspark, 20 Jun 2005.
  1. Headspark
    Headspark Minimodder
    23 Feb 2005
    why are there 3 ports on some CPU cooling blocks i have seen, what is the advantage, if any in having them.
  2. lord nicon21
    lord nicon21 sexy *******
    29 Sep 2003
    are you asking about watercooling?
    where the water gos in the min one and out the 2 at the side
  3. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    A block with 2 outlets should have less resistance. However with most setups and a Y straight after the outlets i dont think you will gain anything. The only advantage i can see is if you return each outlet directly to the res.
  4. jjsyht
    jjsyht Hello, my name is yuri
    19 Jun 2004
    An application of two outlet i came up with consists of making each outlet go to seperate water blocks (video card, etc), and join again just before the pump.
    The reason* for this is that pumps will try to get as much water from its inlet as possible. This is specially true* with a modded DCC pump where the inlet is 1/2" and outlet is 3/8" and you are using a "2x3/8" to 1x1/2" Y connector".
    * These are only my opinions, it hasn't been tested nor scientifically proven, so you're welcome to say its completly false.
  5. Nexxo
    23 Oct 2001
    Split loops are bad, mmmokay? Just don't go there. For starters, 2 x 3/8" is not equivalent to 1 x 1/2".
    Centrifugal pumps indeed do not like any restriction of the inlet.
  6. Breach
    Breach Modding in Exile
    20 Jun 2005
    Usually on tripple barbed blocks the point is to have a jet style inlet over the pins letting the liquid out on both sides like the Danger Den RBX, although it has been proven that the same thing can be done with a 2 barb design like the TDX, essentially an RBX with one less barb to deal with. At least thats what I think I know.
