Modding 3 pronged screwdriver?
Discussion in 'Modding' started by craigey1, 2 May 2003.
  1. craigey1
    craigey1 Minimodder
    13 Jan 2003
    It's a bit hard to describe.....
    Does anyone know where I can get a phillips screwdriver that has 3 prongs for holding a screw. I used to have one, but it seems to have diappeared and now I can't even find one on the net / high street.
    Anyway if you don't know what I'm talking about then post below and I'll try to explain things a little more clearly.
    Thanks
    :thumb:
  2. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    theres a little tool that i used to have, with 3 prongs, and u push it like a pen and it extract 3 prongs, if this is what your talking about, its an electronics part to hold electronics while you solder them, like resistors, capacitors, and IC chips.
    this doesnt tell you what its called or where to get it but it may jog someone elses memory who reads the post :eek:
  3. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    *realization dawns*
    Ahhh... I see what you mean.
    Would be usefull, (Magnetized screwdrivers aren't good inside a 'puter)
    but with the differing size of screw heads these days, not very practical, IMHO.
    Can't find any, sorrry.
  4. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    i know what you mean.. its like a clip that holds the screw on the tip of the driver... check at sears maybe.. i never liked them anyway, the retainer thing always got in my way...\
    -scoob8000
  5. Morphine
    Morphine weeee!
    23 Feb 2002
    I belive its a craftsman thing you can find in sears. My dad used to have one, but lost it
  6. craigey1
    craigey1 Minimodder
    13 Jan 2003
    Exactly like that.
    But they are perfect for the screws that hold in you M'board and Cards. (The prongs grip round the head of the screw, to stop the screw falling on to the board)
    Sounds similar, just with a screwdriver in the middle of the prongs.
  7. craigey1
    craigey1 Minimodder
    13 Jan 2003
    any ideas to get one in the UK? Or anyone fancy buying one for me, which I will pay them for? That is if you can find it.
  8. Dad
    Dad You talkin to me?
    15 Apr 2003
    AH HA! A screw starter! Okay, I was getting REAL confused for a while...
  9. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    Erm why ? unless ya store floppies inside ya PC (Not used a floppy for months meself.. :)
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Magnetic bits are the best thing since sliced bread. :clap: :clap: :clap:
    A bit of sticky tape round the screw head and driver tip is a poor runner-up for brass screws. :clap:
  11. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    There also may be some goo you can get at the hardware store to make the screw stick to the bit. I can't remember the name though.
  12. Oclocker
    21 Jun 2001
    Oh ya mean Magnagoo - wonderful stuff works almost as well as a magnetised screwdriver :)
  13. Amorphus
    Amorphus What's a Dremel?
    25 Feb 2003
    how does it come off?
  14. Oclocker
    21 Jun 2001
    What come off?
