3000+ or 3200+
Discussion in 'Hardware' started by Superlunchbox, 14 Jul 2005.
  1. Superlunchbox
    Superlunchbox What's a Dremel?
    13 Jan 2004
    I have a question. I heard that the 3200+ overclocks better because of the multiplier being higher. Is this true?
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    They should both clock about the same. The 3200 will be "easier" to overclock as it has a more favourable multiplier. HAving said that, it doesnt really matter with A64 since you can run dividers with no penalty.
    Go for the chip that you can afford or that has the best stepping if you can get that info
  3. Superlunchbox
    13 Jan 2004
    Thanks, I'm going to need to read up on the whole divider thing, because I don't really understand it too well. I want to try to run everything synchronously.
  4. phuzz
    phuzz This is a title
    28 May 2004
    You might find this helpful then...
  5. Superlunchbox
    13 Jan 2004
    Good article, that cleared up a lot for me. I can't wait to get this new system...
