LOL 315kmh + not so reliable laptop bag = ?
Discussion in 'General' started by Andersen, 27 Aug 2010.
  1. Andersen
    Andersen Brain for hire
    25 Nov 2002
    That is one sturdy laptop.
    Clicky
  2. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    The laptop was probably travelling around 31.5 km/h before impact, down some stairs or something like that :eyebrow:
    315km/h :confused: And it supposedly landed in grass, causing a massive dirt cloud... so i suppose the macbook can also survive being washed :rolleyes:
    Yeah, whatever :hehe:
  3. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Oh, I have seen worse.
    A couple I remember now was one that had been run over twice by a tractor. Still worked except for a cracked screen.
    Another one that had been in a housefire. The plastic on is was all curly and charred (and a horrible smell). Everything on it still worked fine. I even fired it up and burned a CD with the customers data using the internal DVD burner.
  4. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    315kph? That's about 195mph! Dubious they were going that fast...
  5. Smilodon
    25 Mar 2003
    That's no problem at all on a motorcycle.
    Of course, the laptop didn't go from 315Km/h to zero instantly, so the speed isn't as much a factor as people think. It only means that the laptop would bounce a lot more before coming to a stop. It's like dropping it from a low altitude several times.
  6. Andersen
    25 Nov 2002
    I wondered about that. Alu MBs weight what? 2kg or so? It would go far but upon hitting something, it slows down pretty fast. Also where would all the dirt be?
  7. Malvolio
    Malvolio .
    14 Dec 2003
    Forget about the dirt (maybe it never reached the ditch, but stayed on the black-top entirely; "side of road" != dirt), where are the skid-marks? I've come across a couple laptops that have been dropped out of a car doing a third of that speed (one was a friend who was rather careless, and the other was found in a ditch), and they've both had massive amounts of skid-marks on, as well as being in several pieces.
    I'd put my money on a small flight of stairs over a spill out of a bag at any speed.
  8. Smilodon
    25 Mar 2003
    Maybe it hit a signpost with a soft mat under it? It sure looks like a single impact.
  9. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    They say they have it working again - an impact at that speed would ruin the hard drive, I'm surprised they had to replace the memory and not the hard drive.
  10. aradreth
    aradreth What's a Dremel?
    20 Aug 2009
    I'm going with it is fake. If it had come off a motorcycle (most of which are limited to 186mph due to a gentlemen's agreement between the big four...) I'd expect the metal casing to be worn down heavily where it had slid along.
  11. xrain
    xrain Minimodder
    26 Jan 2004
    I'm almost certain that laptop would need to be scooped up with a shovel if it hit going that fast. It wouldn't only hit once, it would hit once then be sent into a high rpm spin as it skipped down the road.
    I suppose it could have hit a wall or something and only hit once, but If it did, I think you would need a vacuum cleaner to gather up all the bits.
  12. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    And then the macbook pro roundhouse kicked Chuck Norris and made him scream like a bitch.
  13. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    SUPERDRIVE FEARS NOT DEATH :rock::rock::rock::rock::rock::rock::rock:
  14. chimmy09
    chimmy09 What's a Dremel?
    26 Jan 2010
    anyone else getting a "cool story bro" vibe off of this?
  15. K
    K 528491
    31 Oct 2001
    Not necessarily. The read heads are parked if the machine is off or even in Sleep mode... So it would probably be fine if it sustained no impact directly.
  16. profqwerty
    profqwerty What's a Dremel?
    2 Jan 2006
    I left my work IBM T42 on the bonnet of my car (defender with flat wings + tread plate) and forgot about it. A while later I drove off, and it came off after 300m when I did a sharp turn - I heard it thunk and suddenly remembered about it in that wonderful sense of realisation you get when you realise you've forgotten your train ticket.
    As is work custom, the hdd wasn't screwed in, just held by friction; it hit the corner onto the road, span several times throwing the hdd out into the grass. The plastic casing was cracked and bits missing (gaffa tape solved that) and the ally lid was mashed at the corners and scrathed badly. Had to replace the hdd but it still works fine :D
  17. Smilodon
    25 Mar 2003
    Proper IBMs (Lenovo) are built to last. I was at a work site where a guy who installed some alarm systems dropped his IBM laptop (didn't notice what model. Probably a T6x or T4x) from the top of a ladder. Screen open and computer running. He just picked it up an continued to work on it. :)
  18. Freedom
    Freedom Minimodder
    27 Oct 2004
    I'm calling Bs on the speed.
  19. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    Eh, one less apple... It just feeds my brazen dislike for their proprietary power connector which the world deserves...
    Impressive it still works though.
  20. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    It is very clean for a macbook that's fallen into dirt. The impacts wouldn't be that bad, though - dropping distance would presumably only be a metre or so. I'd expect a laptop to survive that (abrasion doesn't wreck anything but looks).
    That said, I recently borked a HDD by dropping it two feet while it was reading. Yeah, it now makes very interesting noises.
