Working on anouther case... That's the window so far. Ignore the paint it's just a base coat... What I'm doing is making a rusted PC, using the look of my neighbor's 1972 civic as an inspiration... the side window is a huge rusthole and the PC is going to be painted green but very old and dirty, and a lot of places the paint is peeling back to reveal nasty rusted metal (and possibly h20 cooling lines if i can find really small tubing and make an adapter for it) Feedback? That was ALL done with a Dremel, nothing fancy just good old elbow grease.
You realy took your time and nice cut, you didnt rush and using the dremel for the small peeks and grooves makes it all look snazzy!!!
This is only my second mod... You guys want a work log? i've taken some pics but I can start taking pics of every step
