Build Advice 32GB RAM
Discussion in 'Hardware' started by Jeff Hine, 17 May 2019.
  1. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    What are the pro's & con's of four 8GB sticks vs two 16GB, in a four RAM slot 'board...?
  2. RedFlames
    23 Apr 2009
    2 sticks tend to play nicer with overclocking.
    4x8GB sets can sometimes be had cheaper than 2x16s
    other than that... ¯\_(ツ)_/¯
  3. KayinBlack
    KayinBlack Currently Rebuilding
    2 Jul 2004
    If you overclock, 4x8 can overstress the IMC and limit your overclock. If you're not OCing then I don't think it matters terribly.
    My system was running 8x4 and it was great. MHW loved it.
  4. Anfield
    Anfield Well-Known Member
    15 Jan 2010
    4x8GB = You have to throw all of it in the trash if you wanted to upgrade to 64GB down the line
    2x16GB = You could in theory add in another 2 sticks to upgrade to 64GB
    (not counting stuff like HEDT / Server boards with more than 4 slots)
    That being said, unless you have a specific use for 32GB go with 16GB and invest the rest in CPU / GPU.
  5. Jeff Hine
    8 May 2009
    Options under consideration:
    Two 8GB
    Two 16GB
    Four 8GB
    Aside from the price and the small fact that I'm currently running 32GB (four 8GB) of 1866 DDR3, I was just looking for opinions as to why 16GB of 3000/3200 DDR4 would be enough?
  6. Anfield
    15 Jan 2010
  7. RedFlames
    23 Apr 2009
    If you budget will stretch to 32GB, awesome... but i'd prioritse other things first, and only bump from 16 to 32 if you've got budget left over. For most things 32 is still overkill.
  8. Jeff Hine
    8 May 2009
    I think either of the Ryzen 2600's & will more than make up for any difference there may be - if any at all - between 32GB of 1866 DDR3 and 16GB 3000 (let alone 3200) DDR4.
    Ryzen 3xxx isn't here with no.'s to play with yet, so I'm working with 'what I have'. :)
  9. Jeff Hine
    8 May 2009
    Amended the title, as that's what it's now become.
    So - 16GB is now a given. This now throws open the door of:
    Will a 2600 or 2600X be happier on a B450 'board...?
  10. silk186
    silk186 Derp
    1 Dec 2014
    I guess it would depend on how much you game and how often your usage goes about 16GB.
    I tend to have a ton of crap open and don't play many FPS games with my 60Hz monitor so I'm considering upgrading to 2x16GB when I see a good deal.
    If your focus is gaming, put it into the GPU as others have said.
  11. RedFlames
    23 Apr 2009
    The X chipset just offers... more... more pci lanes, more sata, more USB 3.x ports. More robust VRMs [typically] and more bells and whilstles and whatnot.
    For most people the B450 boards are sufficient if you're thinking of dabbling in overclockgin and just running a single GPU and 1x NVMe SSD and a few USB peripherals. If you think that might a limitation now or in the future then opt the x470 [i wouldn't bother with a B350/X370 board tbh].
    You don't need an X chipsetted board to use/get the best from a X monikered CPU.
    Jeff Hine likes this.
  12. Jeff Hine
    8 May 2009
    My findings are leaning towards a 2600 on a B450, w/ 16GB 3200 & a Dark Rock 4 - more specifically these.
    Add in my (recently acquired) Vega 56 & 28" monitor & I think that should do me for "5 years"...
    EDIT:
    If Zen 2 kills current prices, I may stretch to X varieties, as appropriate.
  13. RedFlames
    23 Apr 2009
    Personally I'd probably opt for the Noctua, or the newer Dark Rock Slim if you're allergic to beige. Otherwise, if it were my money that's more or less what i'd buy.
  14. Anfield
    15 Jan 2010
    Dark Rock 4 won't be an option if you want to go AMD, you'd have to wait for the new Dark Rock Slim to turn up in stores (as that one has AM4 compatibility), or go Noctua (as those have been updated for AM4).
  15. RedFlames
    23 Apr 2009
    IIRC BeQuiet do offer an AM4 kit for the Dark Rock 4/Pro 4 but you might have to contact them directly for it.
    But from what i've seen the Slim performs similarly to the Dark Rock 4 and ofc comes with the AM4 mounting in the box.
  16. BA_13
    BA_13 Active Member
    2 Sep 2011
    I had a dark rock 4 on my i9-7900x and was very disappointed with it (Came in an overclocked bundle from Scan) replaced it with a corsair i150. It was quiet but thats all I can say for it. It couldn't handle the CPU at 100% load before overclocking without throttling.
  17. Jeff Hine
    8 May 2009
    What (sockets) are the 2-part back plates for...?
  18. nimbu
    nimbu Well-Known Member
    28 Nov 2002
    I just went 2x16 GB in my rebuild. Given I'm itx I only had two slots and figured that it's one thing less to have to upgrade.
  19. Jeff Hine
    8 May 2009
    OK; says/implies here that the DR4 is a bit of a beast, but the Pro 4 & the Slim give better RAM slot access/clearance.
    The Slim fits within my budget, but it's not listed here...
  20. adidan
    25 Mar 2009
    They have it at OCUK, CCL and Scan at least.
