350 notes Rig Upgrade - Advice pls
Discussion in 'Hardware' started by deadeazi, 6 Oct 2006.
  1. deadeazi
    deadeazi What's a Dremel?
    6 Oct 2006
    Hello :rock:
    I've got 350 hard earned notes to spend updating my rig.....
    Currently
    AMD Athlon 64 3500+
    Abit Fatal1ty AN8
    2GB Corsair XMS PC3200
    ATI Radeon X800 XL (R430)
    Creative SB X-Fi Platinium
    74GB Raptor & WD 200GB
    Any suggestions....
    I'm thinking of putting in a....
    AMD 4800+ X2
    and a
    Nvidea 7900GS
    Thx in advance :thumb:
  2. FaiNT`
    FaiNT` What's a Dremel?
    1 Sep 2005
    Yeah, a 4800X2 would be my first suggeston, because bar your CPU and graphics card, your rig is pretty good. Not sure what to suggest for a graphics card. Alternatively, you could get a slightly cheaper CPU and get a decent graphics card....it's up to you really, what do you use your machine for?
  3. deadeazi
    6 Oct 2006
    gaming....
    battlefield 2 mainly
  4. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    you could get a X2 4200 and then a 7950gt thatd be better for gaming, plus you could just overclock the athlon anyway
  5. Noni
    Noni What's a Dremel?
    8 Dec 2005
    Yeah, even a 3800X2 will do, and a 7950GT/ 1900XT
  6. Austin
    Austin Minimodder
    16 Jul 2004
    :D Yup X2_3800+ or X2_4200+ and o/c combined with a 7900GS, 7950GT or 7900GTO. That should tide you over for a good while, until quad-core, DDR3 and DX10 are all mature and well priced.
  7. deadeazi
    6 Oct 2006
    decided to blow my budget slightly (50quid) :eeek: (last months overtime)
    decided to go for a 4800+ X2 & a 7950GT
    thanks for the advice though............ :cooldude:
