Cooling 360 or 420 AIO CPU Coolers - Which ones
Discussion in 'Hardware' started by bdigital, 11 Jun 2020.
  1. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Hi all,
    So after learning that my H110i GTX needs a few taps to get flowing each time, I have decided to look for a new (bigger) cooler. (yes I am looking at RMA with Corsair but I will need a replacement before I remove it).
    So, I am currently looking at this 420 from Alphacool - It has 3x140mm fans which I like the thought of over the 120mm. Anyone have any experience of it? Lots of reviews in German ;)
    Alphacool Eisbaer Aurora 420 CPU
    Or theres plenty of 360mm ones from the likes of Corsair, NZXT, Cooler Master etc - Any stand out performers I should be aware of?
    Ive been out of the game for a while now so im not up on which ones are the best performers. I know you guys and girls will have some solid options.
    Thanks in advance
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    What are you cooling?
  3. Vault-Tec
    30 Aug 2015
    Translate the reviews to English?
  4. bdigital
    10 Aug 2010
    i7 3960x Socket 2011 - Gets fairly toasty but nothing extreme
    Yup! Been reading through a few now. Still always welcome some real world stuff from here - Always value others experience !
  5. Bloody_Pete
    11 Aug 2008
    A 240 would probably be plenty for that chip :)
    In terms of reviews, Gamers Nexus are really solid for AIO's, so probably worth looking there :)
    Edit: I meant 280 :duh:
  6. silk186
    silk186 Derp
    1 Dec 2014
    I would go with a 280mm for noise and case compatibility. I can't imagine too many cases accommodating a 420mm radiator.
    Alternatively, a 360mm radiator offers more top mount case support.
  7. Vault-Tec
    30 Aug 2015
    They get hot if they clock well. I had the 3970x and it clocked like a nutter (5.2ghz all cores) but I had a 280mm H110? something like that. They do need some cooling tbh.
