Xbox 360 360 & plasma tv
Discussion in 'Gaming' started by heir flick, 5 May 2008.
  1. heir flick
    heir flick Active Member
    2 Feb 2007
    i have a SAMSUNG PS50Q97HDX tv with a xbox 360, last night i was playing need for speed most wanted, after about an hour i turned the 360 off and while the screen was black i noticed i could still see a shadow of the speedo in the bottom left of the screen and after a quick panic attack i turned the screen white using the anti screen burn in the tv settings and left it for 10 min, this seemed to do the trick as it was now gone, i have had a look around the net at tv forums and others have had this with there samsung plasmas but have said what looks to be screen burn soon disappears on its own, but must admit it does not sit easy on my mind and would like to ask if any of you have samsung plasma and what are your experience with gaming consoles
  2. lewchenko
    lewchenko Member
    17 Dec 2007
    I have the same TV. Have noticed similar things with both the Sky+ box (if you leave it on the menu system for a while) and also with my PS3. Its a *feature* of plasma's Im afraid. Technically its a mild form of burn in, but no way near as severe as it used to be for older plasma screens. You can correct it like you did, or with heavily moving images for a while. I just put the TV back on, and in a few mins... the images fade away.
    Not ideal, but the TV was a bargain to be honest. Paid about £800 for a 50inch plasma at 1080i/720p. Great picture for normal TV/Sky and upscaled DVD's plus PS3.
  3. FIBRE+
    FIBRE+ Active Member
    27 Feb 2005
    Yer don't worry about it, it happens on plasmas.
  4. Veles
    Veles DUR HUR
    18 Nov 2005
    Yeah that's the problem with plasmas, that's the reason you don't get plasma monitors.
  5. DarkLord7854
    DarkLord7854 New Member
    22 Jun 2005
    That's why LCD monitors rock :p
    Also due to the fact that plasmas are rather fragile last I heard.. you don't really wanna jiggle them when they'reon
  6. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    have been wondering why they never released plasma monitors
  7. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    I've had it on my 42" plasma (Philips) as well, disappears after sticking a DVD or TV program on (haven't figured out if it's got a anti burn-in option yet, there's nothing in the menu).
  8. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    I heard you can't turn a plasma upside down, or they leak.... or something...
  9. Hazardous
    Hazardous New Member
    21 Jan 2004
    Yeah... you should always try and keep them upright if they have to be moved :idea:
  10. koola
    koola Active Member
    11 Jul 2004
    Any phosphor-based screen can suffer from burn-in, which includes Plasma, LCD (except LCoS and DLP) and CRT. It's caused by uneven wear of phosphors in the display.
    Just to clarify, they BOTH suffer burn-in issues.
  11. Veles
    Veles DUR HUR
    18 Nov 2005
    I thought LCDs weren't phosphor based at all?
  12. will.
    2 Mar 2005
    My old CRT used to have a permanently visible start button :p
  13. Blademrk
    21 Nov 2003
    True, just look at your local hole-in-the-wall and you can usually see the outline of the main screen.
  14. badders
    badders Neuken in de Keuken
    4 Dec 2007
    My El-cheapo Rebranded Hitachi LCD gets this occasionally on the Sky Menu if it's left on for too long, so it definitely happens on (some) LCD's too.
  15. heir flick
    2 Feb 2007
    thanks for the replys guys, didnt want to carry on gaming on it if it buggers up the screen, watching a film with a cod4 map in the corner of the screen would spoil the enjoyment slightly
  16. koola
    koola Active Member
    11 Jul 2004
    Not all are, but most still use this tech as it's cheap and fairly reliable plus the manufacturers always stick a MTF on them so they are covered.
    This issue is what screen savers are for ;)
  17. ChriX
    ChriX ^
    30 Aug 2001
    From what I've read, you need to abuse the newer plasmas really bad to actually get something to burn in - i.e. hours and hours of static stuff. It seems the stuff you might see out of normal use is just called image retention and perfectly normal and will disappear, but again some screens better than others. I really prefer plasmas as (at least to my eyes) blacks, colours and SD performance seem superior - obviously only if you're going large enough otherwise there's no choice.
    Apparently the resistance to retention/burn-in improves after the initial run in period as well.
    I did far too much reading as bought a TV recently. :)
  18. Amon
    Amon inch-perfect
    1 Jun 2007
    If your screen has a display profile for video games (effectively, it filters out high-contrast tones), then use that on whatever input you have your Xbox connected through. If not, create your own display profile and dampen the display contrast and brightness. Besides, Samsung doesn't produce quality plasma displays to begin with.
    Not on my Pioneer display.
    They're not that fragile, but it largely depends on the manufacturer; they should have a one-piece internal steel frame that is used to support its weight when wall-mounted and useful for shock absorbency. But you'll only find plasma displays in sizes 42 inches and larger, so, logically, any television set of that size is fragile.
  19. DarkLord7854
    22 Jun 2005
    Well I meant, they're rather susceptible to shocks, tremors, and sometimes even slight movements. Least the ones I've seen were
  20. koola
    koola Active Member
    11 Jul 2004
    Then you obviously haven't bought quality.
    Plasmas are no more at risk of damage than LCDs are. My Panasonic Plasma has been through a mini earthquake, a small drop when wall mounting it and it's still alive and kicking. There're really no massive differences between them only that Plasmas offer superior colour definition over an LCD equivalent.
