Cooling 360 rad - which way up.
Discussion in 'Hardware' started by Risky, 13 Jan 2008.
  1. Risky
    Risky Well-Known Member
    10 Sep 2001
    It's a while since I posted here and to be honest I'm bit hazy on some of my w/c so I though I better ask.
    The new project is in a big server case and I'm fitting an Alphacool NexXxoS Xtreme III vertically between the drivebays and the board. My only question is whether I should have the onnections at the top or bottom. at the bottom will make it easier to drain the system but ther is a possible air-trap. The pump is a DDC pro so should have be enough to flush it out or is it better to connect at the top?
  2. Guest-23315
    Guest-23315 Guest
    I'd rather have the barbs at the top, as its easier to get all of the air out of it. It was much easier to bleed when I turned my rad upside down (from at the bottom to the top, when I was using a NexXxos II and a DDC Pro)
  3. LVMike
    LVMike New Member
    11 Aug 2004
    it does not really matter. both position will trap some air, so you will have to rock your case a little. I prefer to mount mine the the barbs on top because its easier to access the hoses if i need to do some work.
  4. keir
    keir S p i t F i r e
    5 Oct 2003
    Doesn't it have a bleed valve for this exact purpose?
  5. LVMike
    LVMike New Member
    11 Aug 2004
    my bix doesn't
  6. Guest-23315
    Guest-23315 Guest
    Only the Thermochills have the bleed screws.
