Displays 37"TV or 2 24"monitors
Discussion in 'Hardware' started by kevie22, 20 Sep 2009.
  1. kevie22
    kevie22 What's a Dremel?
    28 Apr 2009
  2. Krikkit
    21 Jan 2003
    What are you going to be doing with this? I'd choose 2*24" generally, but it depends on the situation.
    Budget?
  3. kevie22
    28 Apr 2009
    movies, iTunes, web etc
    budget is about £400
  4. bagman
    bagman Minimodder
    18 Apr 2009
  5. kevie22
    28 Apr 2009
    Looks very nice but i would like 2 monitors for the price of that or the extra space of a 37" tv
  6. bagman
    bagman Minimodder
    18 Apr 2009
    you can't get a good sub £200 24" monitor but you can get 2 good 22" monitors for £400
  7. Combinho
    Combinho Ten kinds of awesome
    5 Aug 2008
    With that monitor, you get the picture you pay the premium for. I would go for that HP monitor if I had the budget, personally.
  8. kevie22
    28 Apr 2009
    And would the HP be better than a 37" HDTV?
  9. Sir Digby
    Sir Digby The Supprising Adventures
    18 Jan 2009
    Personally I'd go for one nice 24" screen with a passable 32" TV.
  10. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    a 37" tv won't really give you extra "space", because it has the same resolution as a single 24" monitor. everything will just take up more space.
  11. kevie22
    28 Apr 2009
    good point
  12. Kyocera
    Kyocera The Garden of Evil
    9 Sep 2009
    As I already explained (to others) you can't compare a TV to a PC monitor.
    The dots on a TV are too big for you to use it for a monitor, you'd get a headache. :eeek: :eeek: your eyes would hurt :waah: :waah: :waah:
    and the experience would not be uplifting.
    you can visit www.tftcentral.co.uk for a deep view on the subject :D
  13. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    exactly, a 24" Monitor will walk all over a 37" TV resolution wise, you'll just get a bigger picture but picture quality will go down, I'd go for the 2 x 24" personally, TV screens aren't normally used on computers for a reason
  14. kevie22
    28 Apr 2009
    and is a £250 24" not worth getting, is the HP worth £150 more
  15. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Ultimately, it depends entirely on how far you will be sitting from the screen. TVs are designed for sitting further away like on a sofa in the living room. PC monitors are designed to sit on a desk only a few feet in from of the user, hence they are usually smaller.
    As said above, if you're only going to have the TV a few feet in front of you then you're going to get a headache, and it won't be a pleasant experience.
    You'll probably have to up your budget if you want 2 24" monitors, but the Samsung T240 is quite well recommended and two of those should only set you back about £450.
    It depends. If you're not that fussy about image quality then probably not, but if you're going to be doing colour critical work like photo editing, then absolutely.
  16. Kyocera
    9 Sep 2009
    I own the HP in question.
    Compared to the classical TN-panel I had before it's another world. And it's huge, you don't need two of them.
    Visit the site I have given you before, there are a lot of comparative photo-shots and you'll see the difference rigt away.
    The PC you're using to talk with us...well, could you not use it's graphic for the next month?
    and now gentleman, pray excuse me, i must climb in my bath tube. :D
  17. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Yer 24" dual screen is major overkill, 22" is the maximum and even that is a stretch, imho non widescreen LCDs look better in dual setup than widescreen ones...
