3800 x2 temps
Discussion in 'Hardware' started by Archtronics, 13 Dec 2006.
  1. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    whats the highest stable temperature when idle do you think my socket 939 x2 3800 will go up to using the retail heatsink
  2. Krikkit
    21 Jan 2003
    What case will it be in? What's the airflow like?
  3. Archtronics
    27 Jun 2006
    coolermaster centurion 1 120 fan 3 92m fans plus heatsink
  4. Krikkit
    21 Jan 2003
    What've you got now? What temp. is it at?
  5. Archtronics
    27 Jun 2006
    runs at about 33 to 36 degrees when idle
  6. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    that sounds normal. i would of said you would get 30 idle and about 40-45 possibly, at full load.
  7. Krikkit
    21 Jan 2003
    What does?
  8. Archtronics
    27 Jun 2006
    ye i still want to know what the maximum safe temp it would go up to
  9. teamtd11
    31 Aug 2005
    as long as your not hitting 50*C full load then you should have no problems. it should never go that high idle, but if for some reason it was 45*C idle. it would still be stable. untill you maxed both cores and took it over 50*C
  10. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Generally, you don't want over 40C idle, or over 50C load, just to be on the safe end, though I suppose you could go higher before the chip actually fries
  11. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    My X2 is at about 40C idle and 50C load. It's stable as and this is bloody hot for an X2.
    Really must reapply that thermal paste soon.
  12. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    My Oppy 175 (Same as X2 4400) runs about 45c at full load with a Thermalright Ultra-90 HSF and quiet fan..
