Cooling 3870K BE Cooler or Arctic Freezer Pro 13 fixing
Discussion in 'Hardware' started by Bogomip, 28 Jun 2022.
  1. Bogomip
    Bogomip ... Yo Momma
    15 Jun 2002
    Hi all,
    Back in 2012 I build a PC with a mini-itx motherboard and an AMD 3870K Black Edition CPU. I stuck a Arctic Freezer Pro 13 on this and crammed it all into a BitFenix Prodigy case.
    A decade later the computer is going strong, however the AF Pro 13 now makes a very loud grunting noise relatively frequently, and I think its because of the small fan between the copper plate and the heatsink (between the heat pipes). I have tried oiling it but alas it seems determined to grunt. So I want to either buy a new, slimmer heatsink/fan for the processor or a new little tiny fan which wont grunt.
    The latter seems harder, but looking around finding information on a new heatsink which will work for the cpu is non-specific, and im not experienced enough to go for a new heatsink without someone telling me to buy it.
    Thus, does anybody know of a good, reasonably slimmer (such 9cm) heatsink I could buy (or scour ebay for) which will work for a AMD 3870K Black Edition FM1 CPU?
    Thanks,
    Bogo
  2. SuperHans123
    SuperHans123 Modder
    27 Dec 2013
    Think you need a system upgrade pal.
    Time to get that wallet out and upgrade!
  3. Bogomip
    15 Jun 2002
    It literally only plays and serves videos, so no need to splash anything - only needs a new fan :)
  4. Vault-Tec
    30 Aug 2015
    The_Crapman likes this.
  5. The_Crapman
    5 Dec 2011
    It's the pro version, which has a tiny fan top of the base plate
    @Bogomip - just remove/disconnect it, it will have little to no impact on performance. As long as the main fan is still fine then carry on cooling :thumb:
    Vault-Tec likes this.
  6. Bogomip
    15 Jun 2002
    Ok I will do that, thanks very much! :)
  7. spolsh
    spolsh Multimodder
    4 Feb 2012
    Yep, that little fan seems to be one of those "improves marketing performance" ones.
  8. Vault-Tec
    30 Aug 2015
    Oh god yeah I would have ripped that thing out years ago lol.
  9. DeanSUNIAIU
    DeanSUNIAIU Minimodder
    11 Aug 2021
    I have the Pro version of this cooler going spare. If you need the fan or the whole hsf, let me know and it’s yours for the postage.
    noizdaemon666 likes this.
