3870x2 - performance bottleneck or powerplay?
Discussion in 'Tech Support' started by -pattoe-, 5 Jun 2008.
  1. -pattoe-
    -pattoe- Member
    20 May 2004
    Ive just installed a brand new HIS 3870x2 1024mb card to my current setup and i'm not noticing any real gains in games compared to my nearly 3 year old 7800gt.
    the system i am using is:
    Win xp pro sp3
    AMD 5600+ x2 @2.8ghz
    Crucial Ballistic 6400 (2gig) (4-4-4-12)
    Gigabyte Nforce 570 board
    Tagan 580w PSU (35A combined) -both 2x3 pcie connectors connected to the card
    all within an antec 900 case...
    3d mark tests @ 1280x1024
    7800gt got about 7500 marks
    3870x2 has 9650 marks on all drivers
    I've hear alot of people saying powerplay isnt allowing the 2nd gpu to kick in and other reports stating that some of them have a duff bios
    I've tried different catalyst drivers 8.1 through to 8.5 - net framework updates, disabling AI in ccc and none of it has made any difference.
    Any ideas?
  2. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    only thing that I can think of is that there may still be some old nvidia drivers on your system and they are causing enough of a conflict somewhere.
    considering how my 1950 pro gets me around 5000 marks you should be getting a lot more performance than that. Even with one card.
    Glad to hear that they fit in the 900 though, now I know that I can get one.
  3. Steve-0
    Steve-0 New Member
    4 Feb 2006
    Corsair 620HX power supply would be helpful.
    580seems small.
  4. -pattoe-
    -pattoe- Member
    20 May 2004
    ah cool, i'll try a driver cleaner when I get home to see how it goes :)
    It does fit in the 900 but theres not much play lol, you have to remove one of the black extra fan holders on one of the hdd racks, good thing is though it just clips off.
    Ive heard alot about the cpu limiting performace also so i'm gonna try some mild oc's on the cpu see if it helps as ive heard 3dmark on a 6400 will get you about 11,000 marks because of cpu limitation.
    Any more suggestions are welcomed.
  5. -pattoe-
    -pattoe- Member
    20 May 2004
