News 3D CPUs to speed computing
Discussion in 'Article Discussion' started by Da Dego, 7 Dec 2007.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. TreeDude
    TreeDude What's a Dremel?
    12 May 2007
    I feel the heatsinks for these would be interesting.
  3. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    need for speed of course............
  4. Djizasse
    Djizasse What's a Dremel?
    5 Jan 2006
    That was my first thought :D
    Was also thinking how the socket would be, 6 sided socket connection, with channels for cooling?
  5. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    picture needing enough room for 5 tuniq towers. one for each side. maybe a mini version of each...
  6. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    Haha.. I read article and was trying to figure out how it would work in any manner of high efficiency
  7. woodshop
    woodshop UnSeenly
    14 Oct 2003
    Does this mean we might be getting Processors that are spears with wire jacks on them?
  8. DarkLord7854
    22 Jun 2005
    The Allspark....
  9. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Providing that the processors aren't hugely 3D, I see know reason why the cooling would have to change much. After all, current processors are multi layered, and these new ones should be more power efficient. Though I have to admit, the mental image of a processor set up like a mini nuclear reactor with cooling running through it is quite cool...
  10. yuusou
    yuusou Multimodder
    5 Nov 2006
    It won't last long, we'll find something even better in 10 years. All we need is a giant to take a step forward.
  11. wyx087
    wyx087 Multimodder
    15 Aug 2007
    the processor isn't 3D....... (i know i can't take a joke)
    they basically says the gates can be overlapped, so opposed to traditional 1 layer of transistors, they can now have multi-layered, so have multiple times the original building space, thus 100MB cache on a CPU may become possible with the current manufacturing technology.
  12. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    if intel or amd don't pick this up i bet via or any other small cpu maker will pinch this technology and become a serious cpu maker rapist....
    imagine a cell processor with this, or IBM snatching this and making God like cpus...
  13. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    I read the Intel tech on this about 3 or 4 years ago. It was a bad idea then and it's a bad idea now. There is no way the heat would be dissipated fast enough.
  14. serialnuber2012
    serialnuber2012 \/\/ho-isky
    8 Aug 2007
    somebody better get out and patent the trademark, "cinderblock" or something... it almost seems like an obvious name for a 3d cpu. "The Cinderblock Tephra -- with pyroclastic flow technology!"
    (Tephra is air-fall material produced by a volcanic eruption regardless of composition or fragment size. Tephra is typically rhyolitic in composition as most explosive volcanoes are the product of the more viscous felsic or high silica magmas.)
  15. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Unless I completely missed the boat, the rest of you have. The article isn't (primarily?) about stacking transistors on top of each other, its about changing their functional orientation. At present, the structure of a transistor is a three dimensional mass of columns and other micro-silicon based structures that have varying electrical properties that allow for them to function as the transistors that make up logic circuits. So far as I can tell, all they are doing is changing the basic orientation so that instead of the silicate layers needed to make the transistors being stacked on top of each other, they're piled next to each other, with the "wires" following the typical design methods of today's processors.
    Or am I horribly horribly wrong? :D
  16. Amon
    Amon inch-perfect
    1 Jun 2007
    I'm baffled how chipmakers didn't come up with and apply this before... I had an idea exactly like this (staggered vertical arrangement of transistors) to reduce die size as transistor counts began to increase dramatically around the the time of K8. I find die size to be particularly important for video cards rather than processors as they have not yet adopted widespread use of multiple graphics cores on one card rather than one gigantic and powerful one. Besides, transistor size isn't getting smaller as quick as it used to, so this sort of arrangement of transistors will have to be adopted soon enough.
  17. liquid_gen
    liquid_gen What's a Dremel?
    12 Feb 2006
    I agree, I think heat would be a serious bottleneck for this technology. I think that however you increase speed, you're going to increase temperature and this is already the biggest limiting factor.
  18. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
  19. ou7blaze
    ou7blaze sensational.
    5 May 2003
    I have a need for speed and also a need to pay the bills.
    Sadly those two can't exist together so I'll go and cry in the corner now :(
Tags: Add Tags
