Education 3D Mandelbrot set found?
Discussion in 'General' started by rainbowbridge, 16 Nov 2009.
  1. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
  2. FuzzyOne
    FuzzyOne
    19 Sep 2002
  3. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Most of the beauty in the mandelbrot set is mapping color to the non-member space - trying to draw that in 3-d would be tricky, though.
  4. wst
    wst Minimodder
    30 Aug 2009
    I don't see the point of these fractals other than... crappy screensavers. Or maybe some weird FPS games. Apart from that... oh, pretty... but that's about it :p
  5. Bede
    Bede Minimodder
    30 Sep 2007
    Have a look on dA then, some of the fractal art there will blow your mind (or at least change it :p). There's been a 3d hack for apophysis for ages afaik, dont see whats so special about this unless the apophysis hack wasnt true 3d rendering.
  6. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    I don't know, a "flying through" screensaver might be pretty awesome, at the cost of raping your CPU / GPU.
  7. Bede
    Bede Minimodder
    30 Sep 2007
    Its an impossibility unless they're pre-rendered, and that takes all the fun out of it, like all 3d rendering of any quality it cant be done in real time.
  8. Furymouse
    Furymouse Like connect 4 in dagger terms
    4 Feb 2004
    Yet
    Just imagine the step above dedicated folding rigs, the fractal render farm.
  9. Bede
    Bede Minimodder
    30 Sep 2007
    An elegant weapon for a more civilised age...where render farms are freely available to all and the rivers run dark with chocolate :D Maybe a use for OnLive tho, have a central cluster rendering ray-traced fractals in realtime and streaming HD footage for your screensaver?
  10. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    I never got why rendering is so much harder on hardware than normal video game rendering, what's the fundamental difference? Aren't they both just drawing polygons and surfaces in a 3D space? Why is Crysis a million times easier to run than something with no textures but very crisp edges?
  11. Malketh
    Malketh What's a Dremel?
    22 Jan 2008
    Well first off Crysis and such use the GPU for that purpose while rendering a fractal does not (lack of GPGPU fractal software thusfar I think, could be wrong), and secondly the equations for fractals typically suck, on an extraordinary level, but that is of course dependant on how many iterations you're doing, which also typically determines how far you'll be able to 'zoom' in since fractal outputs are typically considered 1.5d instead of 2d.
    Don't quote me on that though since the last time I dealt with fractal math on any kind of level I was still a kid and my father was doing some rendering on an old ass 286.
  12. Bede
    Bede Minimodder
    30 Sep 2007
    With games, textures, models etc are pre-loaded and use optimised code. Fractal rendering is rendering from the bottom up, you give it some units and basic pathways to follow (like julia etc) and it then works out firstly what it is, then what it looks like. With games, GPUs just have to work out what it looks like. Then there are tricks and tweaks that can be used to speed up rendering, but at the end of the day if you are doing 3d rendering you're also working out the fall of light on an object - and with fractals there are millions of planes for secondary reflection as well as the sheer intricacy of the fractal itself.
  13. wst
    wst Minimodder
    30 Aug 2009
    I don't want my screensaver to use more power than I use...
    Just saying...
