Graphics 3D Mark 2003 Scores
Discussion in 'Hardware' started by Fowler, 11 Feb 2003.
  1. Kingskin
    Kingskin What's a Dremel?
    17 Aug 2004
    6438 witht the system in my sig.
  2. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Radeon 9800 Pro Flashed To XT @ 430/378
    Rest of spec in sig
    Quite pleased, anyone with 9800 Pro and R360 it's worth the flash, check my post in bargain bin for the 9800 Pro's with R360 :D
  3. fatty
    fatty Minimodder
    12 Jul 2004
  4. xckid082488
    xckid082488 Banned
    18 Sep 2004
    6275 3DMarks with omega drivers, should I try Catalyst 4.9?
  5. TMM
    TMM Modder
    12 Jan 2004
    yeh, omega drivers are tuned for stlightly better image quality with a little less performance, but not alot slower at all. Try the cat 4.9s and see which is better :)
  6. Leeum
    16 Feb 2004
    I've never had much luck with Omegas, i installed them and it just artifacted at the overclock that was stable with the ATi Cats.
  7. squishedhog
    squishedhog What's a Dremel?
    18 Nov 2001
    jus done a 6302 in 2k3 :)
    rig in sig...
  8. squishedhog
    18 Nov 2001
    that's with cat 4.9's, the ati dynamic overclocking thingy on the drivers switched on, but no other o/c'ing... :)
    (n thanks to whoever put the avatar on for me!!! classic :D)
  9. squishedhog
    18 Nov 2001
    jus got 6524 with a slight overclock of the card - now running 425/389 but I think there's a bit more to come from that! it's a proper 9800XT, not a flash of a pro...
  10. TMM
    TMM Modder
    12 Jan 2004
    2500+ @ 2.2
    9800pro R350 @ 426/381
  11. cougar911
    cougar911 What's a Dremel?
    19 Sep 2004
    my 5900xt oc450,900 3dmark2003 5786
    just so so
    1800+ oc 2200
    256mb pc3200 *2
  12. zapf
    zapf What's a Dremel?
    17 Aug 2004
    what did i do wrong if i have a 3400+, a 6800gt, and 1gb of ram and got 5150?
  13. Mister_Tad
    27 Dec 2002
    an afwul lot
    check cool and quiet is bringing the cpu back up to speed (if its on)
    check that the cpu isnt throttling
    check that the card is clocking to 3D mode
    check that the card is in AGP mode
    make sure you dont have AA and AF turned on in the control panel
  14. ab1385
    ab1385 What's a Dremel?
    29 Aug 2004
    Athlon 54 2800+
    512MB OCZ Premier
    XFX 6800GT @ 400/1100
    11700 3D Mark '03
  15. zapf
    17 Aug 2004
    Ok, so I scored twice as much when I turned down my gfx settings.
    11,292
  16. diskreet
    diskreet What's a Dremel?
    1 Oct 2003
    ON DEFAULT SETTINGS:
    no cheating on settings people!
  17. madgeordie2004
    madgeordie2004 What's a Dremel?
    1 Oct 2004
    Sorry guys,
    I've got 20478
    amd 64 3200
    msi k8t mobo
    512ddr twinmoss
    radeon 9800pro flashed to xt
    a couple 80gig s-ata
  18. madgeordie2004
    1 Oct 2004
    sorry
    I got 20478, 7066 03marks
    amd64 3200
    msi k8t mobo
    512 twinmoss
    9800 pro flash with xt bios
    a couple 80gig s-ata's :cooldude:
  19. smit101
    smit101 What's a Dremel?
    10 Jul 2004
  20. Hiren
    Hiren mind control Moderator
    15 May 2002
    My lastest I'm pretty happy with it. :D
