Graphics 3D Mark 2003 Scores
Discussion in 'Hardware' started by Fowler, 11 Feb 2003.
  1. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Accidently posted in the other thread, but 2750 for me.
    Altron, yes it will. Think of it this way: would it be safe to say that just because both a Geforce 2 and a Radeon 9700 Pro can run HL at 100fps means that they perform roughly the same? Hells no. A Radeon can do all sorts of freaky **** that'd make a Geforce 2 **** bricks (as some people have found out trying to run 3dm2k3).
  2. sotong
    sotong What's a Dremel?
    12 Feb 2003
    Managed to get a score of 4613 on a R9700 Pro with P4 2.53Ghz
  3. Altron
    Altron Minimodder
    12 Dec 2002
    I need a new video card.
    I hit 10fps once the entire test (and I don't mean that was the lowest I got ;))
    I had trouble installing Directx9 to run it.
  4. Thorny
    Thorny What's a Dremel?
    2 Aug 2002
    Just overclocked my 9700 pro a bit and got 3743
    might need a bit of water cooling action to get it higher. dont know whats stoping mine from going above 4000 like the rest of the 9700 pro'ers
    Mind sharing the settings of ure cards?
  5. drunkenmaster
    drunkenmaster What's a Dremel?
    5 Jan 2003
    Whats teh rest of your rig?
    Likely candidates would be cpu if its dead old, under the 1.5gig mark, fsb if pretty low, errm.
    Defrag hard drives, run straight after reboot.
  6. Skatanic
    Skatanic What's a Dremel?
    11 Feb 2003
    I got 1448 with a 1700(stock) and a leadtek ti 4200 at 270 , 500
  7. sotong
    12 Feb 2003
    My R9700 Pro is at default, so is my CPU
    Your system is pretty high end, I don't see why you should not get 4,500 or so. Are you using the latest drivers?
    If updating drivers still doesn't help, check that u have not accidentally turned off some things in BIOS eg L2 cache
    Worst to worst, do a clean format
  8. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    I got 133.. w00t... LOL
    I can't even run the demo... *sniff*
    I wonder about that one theory about dividing your 2k1 score buy your 2k3 score...
    3500/133 = 26.315... nope, I guess not...
  9. Henry
    Henry Matrix Orbital
    13 Jul 2001
    AMD 1600XP+
    512 PC2100 Micron DDR
    512 PC2700 Micron DDR
    80gig 7200rpb WB Drive with 8megs cache
    TI4200 128megs of ram
    and I get a 863... is this good?!?!? I don't think so... and why could I only run 3 of the 4 demos... what's special about this last demo!?!?!
  10. sotong
    12 Feb 2003
    LOL!!!
  11. sotong
    12 Feb 2003
    No, a Ti4200 should get around 1,200 to 1,500
    The last demo is the nature test - wondering why a Ti4200 cannot run that
  12. drunkenmaster
    5 Jan 2003
    Cos it needs dx9 hardware not just software. So only cetain radeon 9k series, and gf fx, (was teh matrox card dx9 or not? canne remember) can run the dx9 hardware tests.
  13. Henry
    13 Jul 2001
    One interesting thing...
    I have 1gig of ram, and through the entire test, the most is used was 31%...
    and I do have DX9.0
    Well.. for the first demo I got 216fps as the fastest and 26fps the lowest...
  14. Mr. Roboto
    Mr. Roboto xBurningMikex
    3 Dec 2002
    ALL stock speeds:
    9700 pro
    amd athlon XP 2100+
    corsair xms ddr pc3000 512mb (not running at 3000)
    Epox 8k3a+
    2 WD400BB@raid0
  15. Ubermich
    Ubermich He did it!
    21 Jun 2002
    670! lol! Man I need a job...
    1.4G T-bird
    GF3 ti200
    soyo k7-ada
    256m ddr
  16. Hwulex
    Hwulex What's a Dremel?
    1 Feb 2002
    O...M...G!! Anyone else watched the demo yet?
    Coz it's the cheesiest darn thing I've ever seen!!
    And WTF is Futuremark's (/MadOnion's) obsession with cows!?!
    Anyhoo, more importantly...
    Result: 1077 3D Marks - [Compare]
    AMD XP1600+
    Epox 8K3a+
    Radeon 9000 Pro 128MB
    512MB Samsung DDR RAM
    IBM 120GXP 40GB x 2
    Fairly pleased with that from my little budget system.
    Every thing's at stock. I've not installed the new ATi drivers yet, and HDD is in need of a defrag, so will do so tomorrow, plus some other tweaks and see what I can come up with :)
    Only ran first 3 tests.
  17. xturmn8r
    xturmn8r What's a Dremel?
    18 Nov 2002
    score
    I feel your pain über... I got an 881 w/ a 1700+,512Mb ddr2100 crucial, and a gf3 elsa gladiac 920..
  18. DaveMustaine
    DaveMustaine What's a Dremel?
    12 Feb 2003
    Pher my score,
    4937
    http://service.futuremark.com/compare?2k3=4818
    Not even tweaking yet, I can easily get more.
    I fell bad for you people with faster procs, i paid 140 for this 1.6A 7 and 1/2 months ago and its only at 2.53 default voltage, i would go higher, but the 200mhz isn't worth not running 3:4 memory multi, 422ddr gives it good bandwidth. i should get more tweaking since my new cooling kit for my radeon 9700pro comes in tomorrow :D.
    Pentium 4 1.6A @ 2.53 (633FSB)
    AVC Sunflower Cooler w/ Artic Silver 3
    Abit BD7-II RAID
    1x 512 Corsair PC3200XMS (running DDR422, 3:4, 3-3-3-2.5-1T, 2.6V)
    Built by ATI Radeon 9700 (350/325, getting cooler tomorrow to tweak more :D)
    Sound Blaster Audigy 1 Platinum (running Audigy 2 hacked drivers 323)
    On-Board Network 10/100 (Realtek 8139)
    100GB Western Digital HDD (7200rpm, 2MB Cache)
    Black Lite-on 16x DVD
    Black Lite-on 32x CD-RW
    Black Floppy Drive
    Enermax 330watt PSU (back and intake fan)
    Custom Painted Metallic Black Cheiftech Fulltower ATX (Same as alienware)
    Self done custom window mod and red cold cathode light
    Custom Handle in the top of case
    Dell P991 (19inch Trinitron Monitor)
    Klipsh 5.1
    Black Logitech Elite iTouch Keyboard
    Logitech MX500 Mouse
    Windows XP Professional w/ SP1
    Prime 95 Approved (24+ Hours Straight, Zero errors)
  19. Dash
    Dash What's a Dremel?
    24 Sep 2002
    My poor ti4200 is dying :waah:
    I really need a new graphic card when doom 3 comes out until then I will need to keep this g card on life support since all I play is UT
    :grr:
  20. Annon
    Annon What's a Dremel?
    22 Mar 2002
    I got the amazing score of
    Drumroll......
    87!!!!
    Simply amazing.
    Duron 1000@1050
    Asus GF2MX 200
    Corsair XMS 3200 512MB
    WD 120GB HDD (8MB cache)
    IBM 60GXP 60GB HDD
    Bunch of other stuff that would have no effect on my 3dMarks....
