3D Mark 2K1 Kicks Out
Discussion in 'Hardware' started by A13n0rma1, 5 Nov 2003.
Thread Status:
Not open for further replies.
  1. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    I was just running a baseline 3D Mark 2001 SE (build 330) benchmark, and out in the middle of the high-detail truck test it kicks back to windows.
    Whats happening?!
    [ or what do I search for on how to fix it, :D ]
  2. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    Try playing around with your bios memory settings... I was getting this for a while.
  3. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    Also make sure that your graphics card isn't overclocked or any nonsence like that, as I've had the same reaction to too high a memory clock :duh:
  4. Carbon
    Carbon Banned
    8 Jan 2003
    i get that too
  5. rich_bytes
    rich_bytes What's a Dremel?
    30 Aug 2002
    If you look in the 3D Mark folder I think there may be an error log that could help you identify the problem.
  6. Zero9
    Zero9 What's a Dremel?
    4 Oct 2003
    tha same thing happended to me until i figured out wat it was. if its doin tha same thing mine did then it would go back to windows at around the time tha truck was goin around tha robots legs. all i had to do was to jus run a virus scan and lt it fix everything and i havnt had a prolem wit it since. so i guess u can jus try that out and see if it works
  7. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    I figured it out, just a bad install.
    A simple reinstall worked perfect.
    Baselined at 10,495 in 2k1. :D
    MODS CAN CLOSE THIS NOW
  8. Tim S
    Tim S OG
    8 Nov 2001
    closed on request :thumb:
Thread Status:
