Modding 3d model maker
Discussion in 'Modding' started by Gajdycz, 27 Nov 2004.
  1. Gajdycz
    Gajdycz Banned
    25 Nov 2004
    are there any freeware programs that i cna make 3d designs in? for modding of course
  2. tmod
    tmod What's a Dremel?
    9 Apr 2004
    SketchUp, search for it here or google it.
  3. [<x>] Kiyusoma
    [<x>] Kiyusoma Deus Ex Machina
    16 Jun 2004
    Yes, a Program called Sketchup.... that's what most use <- Recommended
    Or..Anim8or but its mostly used for 3d animating :D
  4. G-gnome
    G-gnome Peter Dickison
    8 May 2003
    Moved to modding.
  5. Fyberwire
    Fyberwire What's a Dremel?
    14 Sep 2003
    Also, MilkShape3D is pretty good. You can do some cool stuff with it and it's farily easy to use.
  6. wmandra
    wmandra What's a Dremel?
    27 Oct 2004
    Try POVRAY using the Moray modeler. Thats what I use and the results are awsome, but it has a steep learning curve.
    Bill
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Sketchup, however good you find it, is a $475 program with an 8-hour free trial. He asked for freeware.
    Please keep warez discussion off the forums.
  8. Herbicide
    Herbicide Lurktacular
    27 May 2004
    Blender (IIRC they used it on one of the Spiderman films) is freeware. The IU isn't brilliant, but hey, it's free.
    - H.
