Graphics 3D Prophet 4000xt 64mb
Discussion in 'Hardware' started by Opticalwares - NDI, 27 May 2002.
  1. Opticalwares - NDI
    Opticalwares - NDI What's a Dremel?
    27 May 2002
    Hiya all!
    I've recently purchsed a Hercules 3D Prophet 4000xt.
    Got it home, stuck it in my pc, waited while it booted, got into xp.
    COnnected to the net, downloaded the latest drivers before i even bothered to look at the ones that came with it,(mainly because the first version of drivers dont usually support xp, and are usually crap).
    Installed the new drivers, tried to play UT and i get an error.
    Click ok, and the game continues in windowed mode, using software gfx :sigh:
    So, i load up max payne, get into the gfx setup, and oh.. i only have the option to select D3D Software mode
    Then i tried half life. Loaded up the game, installed the latest patch (1.1.0.9 if u didnt know about it) and tried to play using open GL (default) and the game crashed.
    So, i reboot, get back into xp, same tihng when i try and play.
    This is really embarassing for me, bacuause i'm no newbie to computer stuff! I thought i was good... Obv not :cries:
    Ne one got any answers?!
    Thanks a lot guys :lol:
  2. herbs
    herbs Nobody but us chickens
    7 May 2001
    Have you got directX 8.1 install?, if you have try to load an older driver that may work.
  3. Opticalwares - NDI
    27 May 2002
    You cant install Direct X 8.1 on Windows xp, apparently, its allready installed :s
  4. herbs
    7 May 2001
    Yeah it is, i forgot :( , other than trying older drivers there isn't much that I can say.
