Graphics 3DMark 11 Extreme Benchmarks (Add yours!)
Discussion in 'Hardware' started by Guest-44432, 3 Mar 2013.
  1. Guest-44432
    Guest-44432 Guest
    So by adding your system specs like I have below, will give other people a comparison to go by.
    So here's mine;
    Spec's;
    3930K @ 5GHz HT enabled
    16GB (2400MHz 10 12 12 31 2T) Running @ 2133MHz 9 11 10 25 142 1T
    3x EVGA GTX 670 F.T.W+ 4GB @ 1346MHz core - 7114MHz memory
    (As I have flashed my cards with a modified vbios, my boost clock on standard is 1228MHz, so with the extra +120, it set the boost to 1346MHz. Also increased the power limit to 300% and Voltages to 1.215v for a real solid stable OC!)
    http://www.3dmark.com/3dm11/6090128
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    As per my signature, two GTX 670 in SLI as follows...
    ASUS GTX 670
    Power Target = 111%
    GPU Clock Offset = 170MHz
    Mem Clock Offset = 400MHz
    Gigabyte GTX 670
    Power Target = 111%
    GPU Clock Offset = 130MHz
    This gives a clock of 1240MHz for each GTX 670 and memory of 6804MHz.
  3. law99
    law99 Custom User Title
    24 Sep 2009
    Top two spot there. Nice
  4. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
  5. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
  6. David
    7 Apr 2009
    No way I'm posting a score in here, with you lot swinging your multi-GPU e-peen around and spraying the walls with Geekosterone! :hehe: ;)
