Other 3DMark 11 Score P, 990x now clocked @ 5Ghz..Score to follow
Discussion in 'Hardware' started by Guest-44432, 11 Mar 2011.
  1. Guest-44432
    Guest-44432 Guest
    Here's my first run @ stock speed.
    P13536
    Link
    Will be back later once I fine my max overclock on my 990x.
    5mins later I test my cpu @ 5ghz. Pics below with awesome low temps.
    Cheers,
    Simon.
    Ljs likes this.
  2. wyx087
    15 Aug 2007
    5GHz 6 cores, 3 580's ...... wow.
    with great power come great responsibilities!
  3. Guest-44432
    Guest-44432 Guest
    After a few hrs testing the best I could do was P14385
    Cpu clocked @4.86Ghz as 3DMark 11 didn't want to with a 5Ghz 990x?
    3DMark11 Link
  4. Pete J
    Pete J Employed scum
    28 Sep 2009
    SWEET!
  5. Silent_Raider
    Silent_Raider What's a Dremel?
    20 Aug 2010
    Very nice, thanks for posting the benches :) ...and making everyone jealous in the process :(
  6. Guest-44432
    Guest-44432 Guest
    Thanks, I guess my avatar says it all. lol
  7. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    Well you beat me by almost exactly 2000 marks.
  8. Guest-44432
    Guest-44432 Guest
    I haven't even overclocked my GPU's yet. I'm sure I can get over p15000, but I'm not going to overclock my 580's until I watercool them.
    Cheers,
    Simon.
  9. KidMod-Southpaw
    28 Sep 2010
  10. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    Its the temps that are amazing for me, kicks ass on my 45nm 930.
  11. Guest-44432
    Guest-44432 Guest
    First time I booted I tried 4ghz @stock voltages (1.20v). It ran flawlessly. Temps where 15c-17c Idle, Maxed out at 34c-37c.
    I change my memory to XMP profile (2ghz) which upped the BCLK to 143 and changed the multiplier to 28. Saved and exit and boom 4ghz @ stock voltages. Awesome!!
    Just an incredible chip, another good move for me..I thinks anyhow:D
    Cheers,
    Simon.
    sleepygamer, Zeus-Nolan and Ph4ZeD like this.
  12. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Hello CustomPC Crazy But Cool section, I do believe we have a contender for the Crazy But Cool PC (he says whilst nursing a semi...)
  13. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    And great bills :p
    its annoying it wouldn't hold at 5GHz though :( What water loop are you using?
  14. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Simon, your sick. +Rep
  15. Guest-44432
    Guest-44432 Guest
    I could of pushed it allot more, but only being a day old, I didn't want to add to much voltage.
    I have 2 water loops, 1 for the motherboard chipset 120.2 with a 750lph pump and 1 is a EK HF waterblock with a 120.3 and a 120.2 rad and 1200lph pump.
    1, RES-PUMP-120.2-CPU BLOCK-120.3-RES - The radiators are located in the bottom of my case with a push/ pull effect.
    2, RES-PUMP-120.2-CHIPSET BLOCKS-RES - The radiator is located on the roof of my case.
    Cheers,
    Simon.
  16. Guest-44432
    Guest-44432 Guest
    Its gotta be done. lol:thumb:
  17. Bloody_Pete
    11 Aug 2008
    Thats excessive... :p
  18. Guest-44432
    Guest-44432 Guest
    But it keeps the temps very low:D
  19. Bloody_Pete
    11 Aug 2008
    If you just used the 360 rad for your CPU you probably wouldn't see a very big rise in temps tbh. When are you going to get a chiller unit for it all then? I'd like to see what you'd get with everything OC'd on a chiller...
  20. Guest-44432
    Guest-44432 Guest
    I probably won't bother with a chiller as the temps are great. (The temps are not holding me back from OC any further, it's the fear of destroying my chip with to much voltage).
    My next move is to put waterblocks on all of my 580's and OC them.
    Cheers,
    Simon.
