Graphics 3dmark doesn't recognize GPU coreclock
Discussion in 'Hardware' started by Payne280, 22 Dec 2005.
  1. Payne280
    Payne280 What's a Dremel?
    19 Oct 2005
    i have my 680oGT oc'd to ultra and when I look at my specs on 3dmark05 it doesn't recognize the core clock but it recognizes the memory clock anyone know how to fix this?
    I am running Driver 8.1.9.5 on my card if that helps at all
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Its a bug afaik. Just stick the actual clocks you run in the description section at the top.
    Its best if you set the clocks before loading 3dmark (that is is you arent alread9=y)
  3. Payne280
    19 Oct 2005
    I set the clocks before I enter 3dmark but it doesn't recognize the core clock and it doesn't show any performance increase
  4. Highland3r
    25 Jul 2003
    Are u setting 2d clocks or 3d clocks? Could explain why theres no performance increase...
  5. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    3dMark03 detects my core clock 100mhz too low but detects the memory fine :(
  6. hitman012
    hitman012 Minimodder
    6 May 2005
    According to 3DMark '05, my GPU core clock is a blazing 8.9MHz :eyebrow:
  7. Payne280
    19 Oct 2005
    I am setting the 3D clock and there is no performance increase to speak of sometimes the score is even lower
  8. Tim S
    Tim S OG
    8 Nov 2001
    graphics cards....
  9. Payne280
    19 Oct 2005
    sorry bigz, thought since it was about overclocking and the problem only occurs during overclocking that I could put it in that section
