Graphics 3dmark scores
Discussion in 'Hardware' started by Carbon, 5 Sep 2003.
  1. Carbon
    Carbon Banned
    8 Jan 2003
    hmm, i did post this last night but i cant be sure i wasnt dreaming :worried:
    now my apollo 3d thrill 128mb card got this on 3d mark 2001
    and my ti4800 128mb only got this
    whats wrong with it :(
  2. herbs
    herbs Nobody but us chickens
    7 May 2001
    If your using the iwill 333r in your sig then you need to enableAli agp to make it go faster and a few memory tweaks with wpcredit.
    To enable the ALi bit either download rivatuner or this. I would try the link I gave you first it is the AGP Enable option on there, if its not ticked tick it then reboot.
  3. DarkRain
    DarkRain What's a Dremel?
    7 Jun 2003
    Last time that happened to me was because V-Sync was enabled and i was getting a maximum of 60FPS in all tests.
  4. herbs
    7 May 2001
    To increase you memory scores which help in games and general smoothness try this, especially if you have more than 1 stick of memory.
    Using these my ti 4200 went from 6800 to 10500 with a XP1800+ and a few extra mhz oc on the cpu and gfx card. Not bad for a mobo that is nearly 2 years old.
  5. Carbon
    Carbon Banned
    8 Jan 2003
    herbs, ive already had to install the ali agp update because my old card wouldnt work on the board and xp for some reason so ill try that memory thing.
    [edit] and also the ali agp control center says its enabled too [/edit]
  6. herbs
    7 May 2001
    Load up 3dmark 2001 and goto the system info then Display Devices followed by the gfx card name and see how much memory is on the "Total AGP Memory" if its 0MB then the Enable AliAgp is not working and you will need rivatuner. Post back and ill msn you or meet you in the irc channel to tlak you through it.
    Don't forget to turn off AA and antistroptic (whatever its called) when benchmarking, and v sync as someone else said. You also didn't post the resolution of the test is it 1024 x 768?
  7. Carbon
    Carbon Banned
    8 Jan 2003
    how do i turn the v-sync off? is that in the display properties>advanced>nvidia thingy??
    yeah i run the tests at 1024 x 768 but i run my normal pc activities at 800*600
    ive looked in the system info thing and ive got this
    Total Local Video Memory: 128MB
    Total Local Texture Memory: 159MB
    Total AGP Memory: 0 bytes
    so its not on.
    my msn addy is knighttable(at)hotmail(dot)com
    cheers :)
  8. micb
    micb Minimodder
    4 Sep 2002
    That score is very low for the setup, you shouold be in the 9000-11000 range with that hardware.
    Make sure you have set you AGP Aperture size to 256 MB in you BIOS, it should be set to twice your videocards memory.
    You can disable VSYNC buy going to you nVidia controll panel, it is in the normal controll panel.
    Click Display icon.
    Then click Advanced button, then click Direct 3D settings and select VSYNC "always off".
    Then benchmark and see what score you get.
    BTW you want to turn VSYNC back on after benchmarking like when you want to play games, as you will see visual tareing when scrolling about if you leave it off.
  9. Mister_Tad
    27 Dec 2002
    what if you have a 256mb video card, agp aperature sizes dont go up to 512mb (not that i have seen anyway)
  10. Carbon
    Carbon Banned
    8 Jan 2003
    i turned v-sync off and got the exact same 3dmark score
  11. herbs
    7 May 2001
    I'm 90% sure its the enable ALiAGP issue, which is the problem with this board at default settings its a POS but with a few tweaks it was the dogs ****s at the time it came out.
  12. Carbon
    Carbon Banned
    8 Jan 2003
    ok, thx for all ya help guys, especially herbs for teaching me how to tweek my graphics and my memory.
    here is a screeny of the much improved score :D !
    ill post some oc'd scores later :D !
  13. Carbon
    Carbon Banned
    8 Jan 2003
    ok, ive done some oc, not great but hey.
    wincpuid
    3dmark
    i need better memory :grr:
  14. Stanmanfoo
    Stanmanfoo What's a Dremel?
    14 Sep 2003
    I had some serious problems with my Radeon 8500DV. I used to get in the 8 to 9000 range, but then after switching motherboards it was giving about 1200 tops. Most times it just crashed running 3Dmark2001. :waah:
    I tried a Radeon 9200 and same deal. This time I couldn't even make it finish the benchmark at all.
    I did a full reinstall of XP and it was all fixed. Who knows.
  15. Carbon
    Carbon Banned
    8 Jan 2003
    iam actually planning a format today or tomorrow (already done the rest of my network :D ) so ill post some screenys then :)
  16. herbs
    7 May 2001
    If you think i'm going to talk you through all them tweaks again you have another thing coming :p j/k
  17. Carbon
    Carbon Banned
    8 Jan 2003
    dont worry about it, good ol' msn6 saved my chat logs so ill just use them :D your advice was simple and strait forward :D
