Graphics 3DMark Vantage Extreme Benchmarks (Add yours!)
Discussion in 'Hardware' started by Guest-44432, 3 Mar 2013.
  1. Guest-44432
    Guest-44432 Guest
    So by adding your system specs like I have below, will give other people a comparison to go by.
    So here's mine;
    Spec's;
    3930K @ 5GHz HT enabled
    16GB (2400MHz 10 12 12 31 2T) Running @ 2133MHz 9 11 10 25 142 1T
    3x EVGA GTX 670 Cheesecake+ 4GB @ 1306MHz core - 7114MHz memory
    (As I have flashed my cards with a modified vbios, my boost clock on standard is 1228MHz, so with the extra +85, it set the boost to 1306MHz. Also increased the power limit to 300% and Voltages to 1.215v for a real solid stable OC!) :D
    http://www.3dmark.com/3dmv/4605979
  2. Guest-44432
    Guest-44432 Guest
  3. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Good to see some GTX 670 representation in the hall of fame! You're representing the budget range here TG :thumb:
    As per my signature, two GTX 670 in SLI as follows...
    ASUS GTX 670
    Power Target = 111%
    GPU Clock Offset = 170MHz
    Mem Clock Offset = 400MHz
    Gigabyte GTX 670
    Power Target = 111%
    GPU Clock Offset = 130MHz
    This gives a clock of 1240MHz for each GTX 670 and memory of 6804MHz.
  4. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
