3dMark2001 Project Question\Problem
Discussion in 'Hardware' started by jetsetjimbo, 30 May 2004.
  1. jetsetjimbo
    jetsetjimbo Up-up and away
    19 Feb 2003
    When looking at the project details for my machine I have noticed that it's recognising my XP-M as a Duron - also it only recognises the speed and fsb pre 8rda.
    It's not letting me publish due to 'detected CPU speed variation' I have read that this is due to problems detecting the CPU speed but mine isn't recognising CPU type.
    Is it 8rda that's at fault or is it just system instability?
    Thanks in advance.
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    CPU speed variation is to a change in CPU speed during the run, this could be caused by instability could try dropping the FSB 1 or 2 or giving a little more voltage.
    As for 8rda try loading /setting teh FSB then loading 3dmark, but IIRC windows logs the boot FSB and i'm not sure if it updates as the FSB changes.....
  3. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Mine shows up as a Duron also, so dont worry too much about that.
    CPU speed variation is down to stability issues.
  4. Dodge
    Dodge What's a Dremel?
    10 Oct 2003
    it doesnt recognise mine
