3dmark2001SE scores
Discussion in 'Hardware' started by Tulatin, 18 Mar 2004.
  1. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
  2. biff
    biff New Member
    8 Jan 2004
    Really :confused:
    I'll have to try dx8 then. I assume you can dl it from M$ and install it even if i have dx9.0c installed?
  3. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    If you have dx9 on there, it won't let you instal dx8. i tried both, and dx9 gave me an extra 100 points.
  4. Highland3r
    Highland3r New Member
    25 Jul 2003
    You can gain 100 points easy from run to run, that doesnt show which drivers etc are better....
    dx8, win 2k (stripped) is the best platform to bench 01 on... changing the test order makes a HUGE difference as well btw, every system is different but try DL, nature, LL, CH, DH, LH, then re-run car low till you get a good run (check fps just as the car rounds the first corner, if you watch there it gives a good indication)
    Dont rush yoda, he'll get there in the end, also stick FULL system specs in the project compare if you can, its a git for yoda to work out, and also it makes browsing the ORB much easier as you see the exact settings people around you are using. The bug with incorrect reading of cpu's makes that hard enough as it is....
  5. yodasarmpit
    yodasarmpit No longer the other Brett.
    27 May 2002
    Cheers for that Highland3r :thumb:
    Don't worry I will get the chart updated soon.
  6. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    Yoda, this is what i got my last 21K score on.
    AMD 64 - 3400+ 2.4Ghz
    1GB OCZ 3200.
    9800 pro - 405/378
    FSB 200.
    Running on air.
    Windows xp pro.
  7. Highland3r
    25 Jul 2003
  8. Highland3r
    25 Jul 2003
  9. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    come on update that list, it needs doing!
  10. biff
    biff New Member
    8 Jan 2004
    Ooooo... Ooooo.... Wait for me to get home and update my Link. It's only a small increase over my last link a few days ago but it moves me up a spot or two.
  11. yodasarmpit
    27 May 2002
    OK
  12. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    C'mon, he's had long enough! :D
  13. Tolsk
    Tolsk New Member
    14 Jul 2004
    someone could update it for him if your in the bg of a hurry he link to the excel sheet is on the bottom of the chart.
  14. Tolsk
    Tolsk New Member
    14 Jul 2004
  15. biff
    biff New Member
    8 Jan 2004
    Sorry for the delay (sick baby). Heare's my new linky
    21351
    All system specs are the same as befor except GPU clock is 500MHz.
  16. Tolsk
    Tolsk New Member
    14 Jul 2004
  17. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    Should be getting more then that matey, my 9800 pro, and 3400+ is kicking your systems ass.
  18. Highland3r
    25 Jul 2003
    Seems about right, he's down on graphics power - check out the nature scores...
  19. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    He should still be beating me, with a 6800...?
  20. Tolsk
    Tolsk New Member
    14 Jul 2004
    2001 is severly processor bias your processor clocks higher then mine, and is a 939 so you have dual channel and a higher clock speed working for ya, and + the clcoks on your gfx are probably higher then mine im only at 325/350
