3dmark2001SE scores
Discussion in 'Hardware' started by j`w0n, 1 Sep 2002.
  1. j`w0n
    j`w0n What's a Dremel?
    17 Jul 2002
    I get about 10100 with my rig...post yours and tell me if mine is okay.
  2. Will
    Will Beware the judderman...
    16 Jun 2001
    Thats a bit low mate...though a bit of tweaking plus the latest drivers will give you a heck of a boost.
    Heres the best I've managed (12081), with the fsb at 144, using the 40.41 detonators and the card overclocked to 340/730 :)
    See Here
    3dmark loves a high fsb and memory speeds, I might be able to push higher but without any memory voltage adjustment I might struggle to get higher than perhaps 150. Also the higher you can overclock your cards core the better with the Gf4....
  3. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Best I've done was 7521. However, since I'm on an SDR system with a GF3 Ti200, that's not at all bad in my book. That was quite a while ago, with 27.70 drivers too.
  4. Lazy
    Lazy Meow?
    13 Nov 2001
    i get about 9000 :)
  5. muse46
    muse46 What's a Dremel?
    25 Dec 2001
    i'll post when i get rid of my gf2mx! and i get hold of 3dmark 2001!
    my radeon 9000pro on its way, and im gonna clock the beatch
  6. Drastik
    Drastik What's a Dremel?
    10 Jan 2002
    I get 2836 on a Geforce 2 MX400 64mb no overclocking. is this good ohh vtw 1024 X 768 X 32
  7. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Drastik- sounds a little low... although depends on the GF2MX
    I could coax 3000 from mine, on a Duron 800@1035, but that was with heavy overclocking on a 32MB MX
  8. muse46
    25 Dec 2001
    drastik's score seems average, lookin at the other scores on there
    the highest 1.4tbird and gf2 MX400 i could find was just under 4000, but im guessing that is with a heavily clocked card
  9. hprcrazyguy
    hprcrazyguy Minimodder
    31 Dec 2001
    Look in my sig, that is the best I have gotten so far. My FSB is at 166. Need to get me a new XP chip. :D
    EDIT: d'oh, forgot about the whole project dolphin thingy:rolleyes:, anyways, thats an athlon 1.2 at 1.414 and a gf4 ti4400 :D
  10. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Well ive managed to get 8274 - dont know if I can get much more out of the proc though.
    That is the 9th highest score on madonion for a prcessor of 1Ghz or less with any GPU/Proc/OS etc
    Link in sig
  11. Guest-16
    Guest-16 Guest
    9908
    With a Radeon 8500 too :dude:
  12. j`w0n
    17 Jul 2002
    Will that score is awesome.
    Tell me what kind of drivers I can get, I only have the 30.82 Detonator drivers...well I don't really cause I get an error trying to install them. Where can I get the latest.
    Then how can I tweak...the highest FSB I can get is 140 then above that I get a blue screen on bootup.
    Last question...why can I only get my video card at 302mhz core...if it's above that it freezes on startup. How the heck did you get it to 340!?
  13. j`w0n
    17 Jul 2002
    Okay never mind about the 302 mhz core...I got it to 315 with no probs. I haven't tried it higher yet because I don't know when it's overheating. What is a sign of the core getting too hot?...does it freeze?...does it give a warning or something?...or does it just fry? There has been nothing unusual with it at 315...I should be able to get it higher.
  14. quack
    quack Minimodder
    6 Mar 2002
  15. n0fear
    n0fear What's a Dremel?
    26 Aug 2002
  16. Will
    16 Jun 2001
    j'won, my score was with the latest 40.41 detonator drivers available from the Nvidia website. These are the first of the 'detonator 5' series, and so are for some people slightly glitchy in games, but performance increases significantly for games and benchmarks where the pixel shaders are used, notice how high the nature demo fps is for my score.
    IMPORTANT: Uninstall the old drivers totally before installing the new 40.41s, they are coded in a significantly different way (using the new CDA code or something) that means installing them over the top of older non-CDA drivers causes problems. Remove the old ones using add/remove programs, then install the newest 40.41s. This should add up to a thousand points onto your score.
    How can i overclock the card so far? 120mm side blowhole over the AGP slot does help ;) its the most effective card cooling you'll ever do. This keeps the card cold to the touch, and with the Leadteks huge heatsink the more airflow over it the better. 340/730 was without any artifacts that show the card is being pushed so far...haven't tried any further though! The higher the core clock on the Gf4 the better it performs.
    If you overclock the memory to far you will see artifacts, white flashes along the edge of textures, or tearing (where the textures are ripped and distorted). If you see this, back off the memory clock 5Mhz or so, before it does damage (which will occur over time if you push it too far). If you overclock the core to far you'll get lock-ups, or geometry errors where the corners of polygons in the benchmark dont meet properly. In which case, back off the core clock by 5-10Mhz until its stable again.
    Push your fsb as far as it'll go, as 3dmark loves that. Be aware that with FSBs over 170 your Gf4 will start to feel the effects of the AGP being so far out of spec, which can damage your card long term. I'm limited to fsbs of 150 or less due to lack of memory voltage adjustment, and as this board will only do synchronous fsb and memory I'm limited to that.
    You'll most probably need to take your memory voltage higher to get a decent fsb, 140 does seem a little low though (sure you're not using the 4:5 ration for fsb:memory speeds?)
    All the usual tweaks for VIA chipsets apply mind, latest VIA AGP driver etc.....check 4x AGP is enabled and the AGP driver is installed in the Turbo mode.
    Hope this helps :)
  17. westeee
    westeee What's a Dremel?
    20 Jan 2002
    13k well slightly over
    thats with
    ga-7vrxp , 1800(149) , 4600 (325/760)
  18. Adam
    Adam Minimodder
    26 Jan 2002
    I'm getting about 4000 on the setup in my sig. Oh dear :sigh:
  19. Liquid K9
    Liquid K9 Human programmer.. heh
    1 Sep 2002
    Bah! I get 0, well 0 in my opinion. damn card wont go further than the gothic-test-thing :rolleyes:. useless Gateway junk.
  20. Fly
    Fly inter arma silent leges
    31 Aug 2001
    I feel your pain bro...
    My Gateway BX mobo based machine scores about 800..
    :rolleyes:
