Other 3GB of My RAM is Cached?
Discussion in 'Software' started by Depetrify, 14 Jul 2010.
  1. Depetrify
    Depetrify What's a Dremel?
    2 Jan 2010
    I have 12 GB of ram on a 64 bit os, why is 3 GB cached?
  2. paisa666
    paisa666 I WILL END YOU!!!
    4 Mar 2009
    cached where? do you have a dedicated graphic card, or are you working with the graphic card integrated into the Mobo, if its the last one then probably its asigning 3 GB of memory to your video...
  3. Depetrify
    2 Jan 2010
    It is a dedicated GTX 295.
  4. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    Because your RAM is there to be used, and it just so happens that the OS knows that too.
  5. gavomatic57
    gavomatic57 Minimodder
    23 Apr 2009
    It's good memory management. I'd have preferred it if it cached more. Don't worry, it gives it back when it is needed.
  6. Guest-44432
    Guest-44432 Guest
    Its called superfetch. I did ask a question about turning this feature off on windows 7.
    Have a read Here.
    Simon.
  7. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    yeah 12gb of ram.. superfetch caches more depending on the amount
  8. glaeken
    glaeken Freeeeeeeze! I'm a cawp!
    1 Jan 2005
    Last week at work, I was up to 9GB of my 12GB being used by windows.
  9. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    Yeah, it's superfetch, it loads up frequently used programs into the RAM ready to open them up quicker.
    I disable the service for it personally.
