Hardware 3rd Dream PC unveiled - Cryo PC Graphite
Discussion in 'Article Discussion' started by Claave, 19 Oct 2009.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. Guest-23315
    Guest-23315 Guest
    I spy a Little Devil phase unit under a different name...
    I aprrove. :thumb:
  3. stonedsurd
    11 Mar 2009
    Doesn't quite do it for me. Seems odd because the PR-talk makes it sound so awesome but it really doesn't pull any of the right strings.
  4. Naberius
    Naberius What's a Dremel?
    20 Nov 2006
    Thats not a dream pc, its a mess!
  5. azrael-
    azrael- I'm special...
    18 May 2008
    Designwise it's just fugly...
  6. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Surely 'GPU' is incorrect? Card, maybe.
  7. Abdul Hadi
    Abdul Hadi Technically, I wanna be tim!
    6 Aug 2009
    The system is just the selection of the most expensive bits in the market. Not the best. So it may be quite quite good but in my opinion not great.
  8. Abdul Hadi
    6 Aug 2009
    Most modders in bit-tech can easily achieve 4.5 from a 975. Just 200MHz more for what, I think 2000 quid. Mmmmm.... may not be acceptable.
  9. Claave
    29 Nov 2008
    It's worth remembering that these machines were specced up a few months ago in order to be tuned, tweaked and stress-tested for reliability, so none of them use HD 5000-series graphics cards. But then, the competition is more about design and innovation than just bunging the most expensive stuff you can find into a case.
  10. Tim S
    Tim S OG
    8 Nov 2001
    Yeah, but will they provide a full warranty, including telephone and on-site support? :)
  11. The boy 4rm oz
    10 Apr 2008
    Looks ok but Meh to the phase. Seriously needs some internal cable work and could have at least used a blue sleeve on the phase pipe to tie it all in. Not to mention the actual case doesn't sit properly on top of the unit and the CF vinyl they used on the case was done very poorly, a ton of wrinkles and bubbles. If that was given to me I would give it back and make them do it again, then again I wouldn't be stupid enough to drop the cash on it in the first place. The second rig is still the best IMO.
  12. oatey4519
    oatey4519 can't be arsed...
    5 May 2009
    Lol..
    It is a bit messy as said as well...
    Nice products inside though..
  13. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Pfft, RAID 0 Intel X25-E would be better, if they wanted to shove the best and the most expensive inside.
  14. Abhorsen
    Abhorsen Minimodder
    10 Apr 2008
    5. Minimise the cost and need for professional technical maintenance or intervention.
    Tim, so.... they minimised cost, yet it's still £7,495. Also they minimised the need for Technical support so a Bit-Techer built machine at £2,000 with albeit slightly lower specs leaves £5,495 worth of Warranty which "Shouldn't be needed" by there own statement... :p
  15. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    Sure as hell ain't pretty.
  16. Baz
    Baz I work for Corsair
    13 Jan 2005
    While the dream PCs are supposed to be awesome, they do still have to at least partly affordable - £2k on 2 SSDs (that are slower than 2x indilinx when reading) just isn't worth it. It's a balancing act between being awesome and keeping things at least partially affordable.
  17. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Just got my copy of CPC in the post, and judging by the front cover alone it looks like you are saving the best for last. It's just a shame that not all manufacturers were quite up to the task in the design department.
    Looking forward to the next two :)
  18. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    well if that's the case (read above comment) then I'm looking forward to them too as these cases haven't really inspired me in the least. Sorry.
    have you ever thought of asking the modders here to create a 'Dream PC' or is that outside the bounds of what is deemed a 'Builder's boutique' with tech support and warranty's and such?
  19. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    I think this is the worst of all five entries. The phase change unit is cool but its a friggin ugly machine. I have just read the full review in the mag and im not that impressed.
  20. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    logan'srun - we do have 'Mod of the Month' and 'Readers Drives' modding competitions every month in bit-tech/CPC, in which any reader can enter their modded system.
    For Dream PCs, we specifically only ask PC manufacturers, so that the systems that are covered can be bought if you like the look of any of them. And while I'm sure some readers might be up for selling one of their modded systems, they wouldn't be able to offer the same tech support/warranty/assurance a PC manufacturer should be able to do.
Tags: Add Tags
