Wii / Wii U 3rd party Wii component cables?
Discussion in 'Gaming' started by Guest-16, 10 Dec 2007.
  1. Guest-16
    Guest-16 Guest
    Are "Joytek" ones worth the £7 saving over official Nintendo ones or are they like the 360 3rd party (VGA) cables and are basically not worth the plastic they're made of?
  2. GoodBytes
    20 Jan 2007
    I got them, and they suck pretty badly.. the connection inside were not well done, so when you moved the cabled it created static on the screen, like a broken RCA cable. I returned them for new cable and I got the result. I tried my DVD player on the same plugs to see if my TV-plugs are fine, and they are. I return back to the store, return them and got the Nintendo official cable and they work fantastically.
  3. bahgger
    bahgger Minimodder
    13 Apr 2005
    I got a set free with my Wii and they're some generic ones but I didn't suffer any problems with quality, so either GoodBytes had a bad encounter with a batch of Joytek or I'm just really lucky! I can't for the life of me remember the brand of cable, or even if it was branded.
  4. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    I had a Joytek composite cable with s-video. I threw it away a couple of days after buying it. Utter rubbish.
  5. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    got some from GAME at the time there was the huge shortage near launch, and they were fine.
  6. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Ive got some Nyko compenet cables that have worked fine for me. I've heard alot of people saying to only use the nintendo cables, but mine work fine.
  7. Firehed
    15 Feb 2004
    I had a set of off-brand cables before I sold my Wii and they seemed fine. But TBH, they don't make much of a difference. Remember, it's still only 480p at best, and I think a lot of the games on the Wii aren't high-motion enough to really see bad interlacing effects (especially when you factor in the low res).
  8. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    I got the official ones from a chappy of ebay for £10 and they are fine.
  9. toric334
    toric334 What's a Dremel?
    18 Nov 2006
    Same, made a hella difference on my 2407.
