Storage 3TB Drive issues
Discussion in 'Tech Support' started by TeenGeek, 23 Aug 2012.
  1. TeenGeek
    TeenGeek Worst touch typing ever.
    11 Feb 2011
    So, today, i built my first computer. it is in a fractal design define r4, with an asus p8z77-v deluxe mobo, 16GB gskill x series ram @2133, 2 GTX670SLI, ASUS dx soundcard, seasonic 1050W 80 plus Gold. i73770k, and two hard drives, one is a 256GB ocz vertex4, and the other is a 3TB seagate barracuda. now,my issue is that i got this computer running quite well, and it is extremely fast, BUT i cant get windows to recognize my HDD, i've looked in the BIOS but i cant figure out how to get it into the boot order, or anything. i can see the thing, when i look in the boot category in advanced mode, but it wont let me put it inot the main boot priorities, and windows cant see it either. anybody know of a solution that doesnt involve re-installing windows?
    Any help is very much appreciated!
  2. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Format the drive. Use the windows install disk to do it if you have to.
  3. jizwizard
    jizwizard Modder
    24 Dec 2010
    Right click computer, manage, disk management, locate drive, new simple volume
  4. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    This.
    You can also go to help and search for disk management if you can't find it.
  5. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    In order to use all 3tb (windows limitations etc etc), you will need to format as a gpt partition.
  6. TeenGeek
    11 Feb 2011
    AHA! excellent, problem resolved now, thank you all for your help!
