Hi, I'm after something like this. but in silver to match my silver V1000. I know Scythe do one in silver but i'm worried it won't match my case. If Lian Li don't do a silver version, is there anywhere i can buy 3 seperate spare bezels (the ones with holes to match the case) and then fit a fan behind it? Any help would be appriciated, as i'm struggling to find what i'm after anywhere on the web
Well kustom pc's do a lian li 3x5.25 bay with 120mm fan and hdd bay (see link below) but that's rather expensive so unless you can make use of the hdd bays then you could try ringing up kustom pc's and try getting just the front plate separate.... http://www.kustompcs.co.uk/acatalog/info_3862.html -Fr4nk
Thanks for the response, i saw that on the website, but i was after something that'd fit the look of a v1000 more, like the black 1 i posted, just in silver, or 3 seperate bay covers such as the plates from this case, but can't find any for sale in the UK.
those things are good but i like the coolermaster 4 in3 , its about the same price and holds hdds as well and all you need to do it cut a bit of mesh to cover the fan and they look the same as the above 120 fan bays
Lian-Li makes one in Silver. It's rather hard to find, but Performance-PCs carries them. However, P-PC is a US site, so shipping to England will be a bit of a problem.
You Sir deserve a big hug! They do ship to the UK, so i've placed an order. Front panel = £25.06, matching my case = priceless Bit-tech delivers!
