Graphics 3x XFX 6970 2GB watercooled or 2x EVGA GTX 580 3GB watercooled
Discussion in 'Hardware' started by LukeDaly, 12 Nov 2011.
  1. LukeDaly
    LukeDaly Pokemon Master
    9 Jun 2011
    Hello guys,
    Sorry titles wrong ment 2 choices not 3.
    Have a question about gpu's for my new rig, I do not have a clue what so ever what to choose, I have come up with these 2 choices.
    3x XFX 6970 2GB watercooled - £1056
    2x EVGA GTX 580 3GB watercooled - £1100
    I want to know which set of cards are better.. not listen to fanboys arguing..
    Many thanks, Luke
  2. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    erm. i THINK the 6970 would be better performing not sure
    cos i dont think theres that much of a gap in performance between the single cards on most games
  3. Bede
    Bede Minimodder
    30 Sep 2007
    If you want to know which set of cards are better, look at reviews. I seriously doubt anyone on here has done a side-by-side comparison of 3x6970s with 2x580s.
    Finally as you say you have no idea what to choose I think it would be good if you clarified whether or not you have multiple screens, as that would really be the only purpose for dropping 1k on graphics cards right now.
  4. LukeDaly
    9 Jun 2011
    Im gona spend the money and get 3 dell u2410's at some point
  5. bulldogjeff
    2 Mar 2010
    I think I would go for the 580's based on lower power requirements being just 2 cards and less heat, performance wise I would say theres nothing in it at that sort of level.
  6. Bede
    Bede Minimodder
    30 Sep 2007
    You might want to wait until you buy the screens then, and get the best graphics cards you can at the time. Current graphics cards are very heavily pushed by 5760*1200, even in Xfire and SLI.
    Otherwise, like bulldogjeff, get the fewest cards you can get away with unless your computer lives in the fridge and you don't mind the electricity bills.
  7. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    This article?
    6970 win on speed while 580's win on power consumption.
    If your spending about 2k on cards + monitors the electricity bill isn't an issue while watercooling will deal with the heat so I'd say 6970.
  8. LukeDaly
    9 Jun 2011
    I have one atm will be ordering another next week, would the 580's use less power?
    and any ideas on if three 6970's is much extra performance?
  9. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    The 3 x 6970's will show better performance.
  10. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    i'd wait for new cards to come out before dropping £1K on the 6970s/580s :p
  11. LukeDaly
    9 Jun 2011
    the new cards arent out for ages tho, and i kinda need them its my work machine.
  12. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    hello,
    what sort of motherboard do you plan on useing please?
    cheers.
  13. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    What work are you going to be using it for?
  14. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
  15. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    Rather than spending a fortune on GPUs and getting three smaller monitors, I'd spend a little more on monitors and get a nice 30" with an accompanying monitor (unless there's some reason you need three 16:10 screens for work), and then run it off two 6970s, watercooled. When overclocked they'll be capable of any game at top settings. This way, you won't come across a game that lacks decent tri-screen support (and there are plenty). Therefore you'll still have a single lovely screen to play on.
    Although I agree with others, just wait around a month or two, and you'll have the new series GPUs out (or announced) which should smash the current cards, with lower power consumption and lower temperatures (and hopefully more overclockability).
  16. LukeDaly
    9 Jun 2011
    Asus Maximus Iv Extreme-z
  17. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    3x 6970's will definatly give better performance!
  18. xxxsonic1971
    5 Dec 2010
    hello bud,
    just looked at the reveiws, a very nice bit of kit
    cheers.
  19. LukeDaly
    9 Jun 2011
    Freelance Interactive Multimedia Designer, basically web design, graphic design video editing etc etc.....
    The screen definately needs to be an ips monitor and 30" ips monitors are big money (well dell anyway). How do you know it will only be a month or two? the latest I can wait would be to the start of december. :(
  20. samkiller42
    25 Apr 2006
    I would pick up a single 30" Dell display over 3 24" Displays.
    Some years ago i picked up my 30" for £700, I know some people have managed to pick up the newer 30's for less than that.
    Sam
