Other 4.0 Android updates for HTC
Discussion in 'General' started by Kovoet, 8 Mar 2012.
  1. Kovoet
    Kovoet New Member
    26 Aug 2009
    Did you try kies air
  2. Panomama
    Panomama I once signed up on uniform dating
    11 Jul 2009
    Got it now (Sensation XE+O2), It's slow, buggy, apps crash etc etc
    Don't upgrade inless you can put up with it
  3. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Right - using the samsung FOTA ive got it updated to: Andriod 2.3.5. Its now saying that there are no more updates though, so whats next?
    I still cant get it to connect to PC via USB. Only kies wifi
  4. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
    On ebay there's many services offered where people can update your phone to the latest OS for a very reasonable fee. Hard to get good guides these days though because ebay doesnt allotw them anymore because theres too much copyright infringement happening.
  5. bulldogjeff
    2 Mar 2010
    That was dead easy Kies air done it all for me. ICS seems quite snappy. My only moan is that all the junk I got rid of before is back to I'm going to have a mass deletion again..Oh well can't moan really.
  6. LJF
    LJF Modded
    6 Jan 2010
    I have 3 usb to micro usb cables from various devices and I couldn't get the 2.3.4 update on my S2 to work...
    ... until I used the short USB cable that came with the phone. It isn't a very technical solution.It may have been coincidence. However, it worked.
    If you haven't already, give it a go.
  7. MrDomRocks
    MrDomRocks Well-Known Member
    5 Sep 2011
    You need to install Keis onto your system. Download Here
    Once installed plug your phone in via USB. Launch Keis and it should detect an update rather quickly. It should be none destructive so you wont lose anything from your memory card or phone itself though with most things synced to email etc it's easy to get back.
    Worked a treat for me!
  8. bdigital
    10 Aug 2010
    Thanks dom but I'm not sure you picked up on my problem. I can't connect the phone via USB anymore. Its stopped working, and doesnt detect that anything has been plugged in. its been driving me mad!!
    I've tried unplugging the sd card, tried it on different pcs etc. No joy.
    I don't have any other cables to try with though. I'm not using the original one but I am using one that has worked in the past.
  9. murraynt
    murraynt Well-Known Member
    6 Jun 2009
  10. bdigital
    10 Aug 2010
    Thanks Murray, I'm not home till after 7pm but I can't wait to try this. If it works il be so pleased mate
    Sent from my GT-I9100 using Tapatalk
  11. bdigital
    10 Aug 2010
    Edit: made the change on my phone but can't test until later. Will report back!
  12. bdigital
    10 Aug 2010
    Ok so, im afraid it didnt make any difference. Ive also tried different cables including the stock one. The thing just wont get recognised on any PC. Loads of stuff on the net, but everyone seems to be fixed by using the fixes ive already tried....they dont work for me!
  13. Kovoet
    Kovoet New Member
    26 Aug 2009
    Bud take it in and they will do it for you
  14. bdigital
    10 Aug 2010
    even though I got it from three?
  15. faugusztin
    11 Aug 2008
    One stupid question - are you using front USB2/USB3 or back USB3 connectors on your case/motherboard ?
  16. bdigital
    10 Aug 2010
    I've tried a mixture of them, plus tried in other PCs and a laptop.
  17. Kovoet
    Kovoet New Member
    26 Aug 2009
    Yes bud all you have to do is take some form of proof of purchase, remember you have a two warranty with a Samsung
  18. MrDomRocks
    5 Sep 2011
    Sorry to hear it still doesn't work mate.....very strange one indeed.
  19. stuartwood89
    20 Aug 2008
    I tried updating through Kies on my Galaxy SII, but it kept failing. I had already rooted my phone prior so this may be the reason. In the end I just installed Oxygen onto the phone, as the ICS update still has the TouchJizz interface, which I don't like (as you can probably tell).
    If you're running a rooted phone, I would definitely recommend Oxygen, as it is pretty much stock Android, and it has a few options built in the settings menu (for overclocking and other neat things). It's an early build but I haven't run into any bugs so far (others have though, but this is early dev build, so only for those who like to mess with things ;) ).
    http://forum.oxygen.im/viewtopic.php?id=2369&p=1
  20. Kovoet
    Kovoet New Member
    26 Aug 2009
    Why is always damn three network.
