Displays 4 displays out of 1 card
Discussion in 'Hardware' started by kryten2x4p, 23 Dec 2009.
  1. kryten2x4p
    kryten2x4p Eek! A Penis!
    23 Dec 2009
    Does anyone have any experience of running 4 displays of 1 card such as the Matrox M9148 LP PCIe x16. This card has 1Gb of memory to share with up to 4 displays. I'm not intending to game, but I do want a decent performance when playing video media and DVD/Blu Ray content. Can anyone suggest another card that will drive 4 displays. I would appreciate any info you have on the Matrox card or similar. Please note that ideally I only want to use 1 PCIe slot as the others are spoken for. Thanks.
  2. smc8788
    smc8788 Multimodder
    23 Apr 2009
    I'm not certain, but I'm pretty sure those are quite expensive compared to normal graphics cards. There are options out there for 3 monitors though, like the TripleHead2Go or ATI's 5xxx series. I'm not sure when the Eyefinity versions of the 5xxx cards will be available, but they'll be able to drive 6 displays natively.
  3. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
    4850x2 2GB.
    Strangely enough, it offers 4x DVI...
  4. PegasusM
    PegasusM Stand back, I'm doing science
    18 Oct 2009
    I agree, go for the 4850x2 2GB, probably a lot cheaper than a Matrox and will deliver solid performance.
    I'm not sure if the cooler will block another PCI slot though? You may want to look into this before buying if you need all the other slots.
  5. docodine
    docodine killed a guy once
    10 Feb 2007
    The card's dual slot and pretty long + hot, but it'll do the job for less $ than any other. +1 4850X2
  6. kryten2x4p
    23 Dec 2009
    Thanks guys. Space will be at a premium. However if anyone could recommend a single slot dual DVI card... I might be able to install 2 of 'em. Mobo will be an ASUS P5Q Premium
  7. 1Razor
    1Razor Living life one day at a time....
    24 Apr 2009
  8. kryten2x4p
    23 Dec 2009
    Thanks 1Razor. A little too long in the tooth.
    What about 2x ASUS ENGTS250 HTDI/512MD3 cards. Twin DVI and PCIe. If I were to get 2 of these, would there be any point in connecting the dual link SLI bridges if I want 4 independent displays?
  9. samkiller42
    25 Apr 2006
    No, you don't need to connect the SLI bridge if your only using it for Media and general usage.
    Sam
  10. 1Razor
    24 Apr 2009
    Of course, they are basically just re-badged 9800GTs! But they are Dual Slot!
    As long as you can live with 2*D-Sub + 2*DVI, just not sure if any lag will be noticeable between the two, depends on how may pixels you want to throw around? If it's just for standard video should be OK - HD you may get slight lag/break up because of conversion, I don't do BD so can't really say.
  11. LT.BEECH
    LT.BEECH Minimodder
    23 Apr 2009
    the gts250 is a rebranded 9800gtx+. but its smaller and only uses one pcie connector.
  12. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    4850x2 2GB.
    I installed one for a client 2months back, kicks out some heat and he could only get 2 monitor out of 3 he was using to work in Windows 7 64bit.
    Around £200 i think it was.
  13. kryten2x4p
    23 Dec 2009
    Ta, everyone. Gives me something to think about.
