Modding 4 displays???
Discussion in 'Modding' started by gstlouis, 2 Sep 2005.
  1. gstlouis
    gstlouis What's a Dremel?
    23 Jun 2005
    So I've done the PS1 LCD mod. I already had 2 CRT monitors and I also have a TV. I have my NVidia 5900XT for my primary card running my CRT's. I have a Radeon 7500 to run the LCD screen and the TV (I've already tested it alone with the lcd, it works great). However, when I plug the RCA jack in for the TV, after I restart my computer, the video card will only do a single display, and by default does it to the TV. The LCD is blank. Powerstrip won't recognize it either. I keep choosing 'extend my desktop' in the display settings(which shows 4 monitors, but the LCD monitor is grayed out), but it just unchecks itself after applying. I've tried tooling with ATI's dual display tab, but it won't let me turn on a second monitor. Is there some way that I can force the output on the LCD screen and also allow for the RCA out for the TV?
  2. Nexxo
    23 Oct 2001
    Perhaps you need to specify the configuration in the Displays Manager of the Catalyst Control Center?
  3. sum41
    sum41 What's a Dremel?
    23 Dec 2003
    i didnt think you could use dual cards when they are radeon and nvidia cards
  4. gstlouis
    23 Jun 2005
    yeah, they work together, I just have a hard time getting the display to work with a second monitor.
    I've figured it out. The reason the PS1 LCD works is because the video card (in most cases) forces a signal to the screen. If you have a video card, enabled, with only one screen hooked up to it, it will force a signal out of that connection. However, when I have the RCA connection hooked up, it chooses that as its primary display connection, and decides that it doesn't need to force a display any more. What I really need is a program that will FORCE the signal out of the VGA port.
    elmodder had a post in the other thread where he tried to do the same thing, but with another VGA monitor instead of a TV. He had the same (lack of) luck that I did. Nuts...
    I think option B will be to somehow take one of my existing VGA connections, and see if I can get a splitter/converter to run off of it, and just put a clone of my second display onto my tv...Either that or I can install a 3rd pci card.
