4-player Mame question
Discussion in 'Hardware' started by Futher, 21 Aug 2006.
  1. Futher
    Futher What's a Dremel?
    21 Aug 2006
    I have a full sized 4-player X-men arcade machine. I am looking to throw a MAME PC in there, but I'm not sure what hardware is required to allow it to be 4-player. Any ideas? Thanks a lot
  2. Guest-2867
    Guest-2867 Guest
    http://www.ultimarc.com/ipac1.html
    IPAC4 should do the trick :)
    Assuming you already have the joysticks and switches available for four players on the machine, you just need to wire em up to this board and away you go :)
    As default, you shouldn't need to configure it as it uses standard mame controls
