A/V 40-42" TV £500
Discussion in 'Hardware' started by M_D_K, 21 Feb 2007.
  1. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Anyone know anywhere that do a 42" plasma TV for less then £500, mainly used for Wii and 360 playing and movies.
    Any recomendations on this not looking for a huge array of connections really.
    I've had a google and a froogling but there doesn't seem to pick up any specifics.
    Thanks
    Morgan.
  2. feckless2k1
    feckless2k1 Minimodder
    2 Sep 2003
    If you want it to be HD then I thinking you'd be hard pressed to find one for £500 new. A second hand SD Plasma around 42" should set you back around £350-400.
  3. DougEdey
    5 Jul 2005
  4. RTT
    RTT #parp
    12 Mar 2001
    Going to be very difficult to find a 42" er for 500 or less!
  5. Atomic
    Atomic Gerwaff
    6 May 2002
    I'd go for a decent HD 32" Screen with HDMI
    The Xbox 360 deserves HD rather than larger and SD.
  6. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
  7. M_D_K
    M_D_K Minimodder
    3 Apr 2002
  8. feckless2k1
    2 Sep 2003
    its only SD though..hope you don't regret it in a few years when everything is High Def!
  9. RTT
    RTT #parp
    12 Mar 2001
    bleurgh :/
  10. kenco_uk
    28 Nov 2003
    MATSUI 42PSD01 - £700 - Cheapest I can find. Probably for a reason :)
  11. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    You get what you pay for and tbh i think you would regret buying that plasma. If gaming is the main consideration i would go for the LCD Jamie listed.
    There are very few 42" LCD's that can match plasma's performance and probably even less that can do it cheaper imo. Give it a year and it will be different how ever.
  12. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    In 42" sizes specifically... that might be true, but did you see last week's 'Gadget Show'?
    Suzi and Jason had to buy a 40"+ LCD and plasma for £1,000 or less.
    Jason bought a 40" Samsung LCD TV, and Suzi bought a 42" Panasonic plasma (which actually cost £120 less than Jason's LCD!).
    They then had members of the film crew watch a soccer match on each, and decide which of the two screens/pictures they preferred.
    The result was a draw... which would suggest there's already very little between LCD's and plasma's at the top end :idea:
