$400 USD Budget Intel Build
Discussion in 'Hardware' started by ChArMz, 28 Jul 2008.
  1. ChArMz
    ChArMz What's a Dremel?
    19 Jul 2007
    Processor:
    E8400 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037 - $175
    E7200 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115052 - $125
    Motherboard:
    RAM:
    OCZ - http://www.newegg.com/Product/Product.aspx?Item=N82E16820227139 - $20
    Power Supply:
    Corsair 450w - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003 - $60
    HardDrive:
    Western Digital Caviar - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074 -$65
    GPU: *doesn't have to be anything major, not going to be used for any major gaming*
    Case:
    CD Drive:
    Have Keyboard, Mouse, Speakers, and Monitor!
    Budget: $430 + $20 Shipping = $450 MAX
    Please help, the only thing I want is the E8400, please make it work with my budget :thumb:
  2. mattthegamer463
    26 Nov 2004
    I don't think it can be done. A usable GPU and C2D-capable motherboard for $110? Half your budget is in your CPU, thats never a good idea. Your CPU would be crippled by the garbage mobo you'll have to buy.
    You would probably be better off with a E7200 and a nicer board and graphics, otherwise you really aren't going to be happy.
    Or, save up another $100 would be the best thing to do if you're hellbent on a E8400.
