PSU 400W-500W ATX PSU for PC-Q08 case (modular?)
Discussion in 'Hardware' started by hm1992, 19 Nov 2011.
  1. hm1992
    hm1992 What's a Dremel?
    28 May 2009
    Looking to build in a Lian Li sff case which require a standard size PSU
    ie. ATX (but not over size, only max 160mm depth and the smaller the better)
    As it is SFF modular would be best.
    I only need minimum 400W PSU.
    What would you recommend?
    I have looked around and modular PSUs are much more expensive and often higher watttage than I need. I'm looking to spend as little as possible but I want the PSU to last me a few years.
  2. Tangster
    23 May 2009
    Silverstone SST-ST50F-P is pretty decent at 500W and around £57, I replaced a Corsair CX400 with one. Not the quietest PSU when under load though.
    Coolermaster Silent Pro M 500W is another great PSU, and at £60 it's a good price.
  3. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    SST-ST50F-P is the fan noisy?
  4. Tangster
    23 May 2009
    Distinct "whooshing" sound when under stress. About the same sound level as a Gelid Tranquillio at 75% fan speed.(For lack of anything better to compare it too).
    Louder than the CX400 it replaced.
  5. hm1992
    28 May 2009
    Im thinking it migh be worth a few extra quid for the coolermaster, quiter operation, japanese capacitors and that chunky internal heatsink. Thanks for your help, I'm stil open for more recommendations though. :)
  6. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    You can buy a short cable kit for the silverstone which is handy in small cases. Might we worth checking if you can get the same for the others your looking at.
