Case Mod - In Progress 42, a GBA carry-case mod. [99% finished]
Discussion in 'Project Logs' started by skreenname, 26 Jun 2009.
What color should I paint the case?
  1. Matte White [ Primer with clearcoat ]
    6 vote(s)
    28.6%
  2. Matte Blue [ Rustoleum Oxford Blue over primer with clearcoat ]
    2 vote(s)
    9.5%
  3. Matte Black [ Rusteoleum High-heat black over primer with Clearcoat ]
    13 vote(s)
    61.9%
  1. skreenname
    skreenname SFF Forever
    11 Jun 2009
    This is my first mod ever.
    Everrr.
    And I'm pretty excited.
    Though I'm kinda nervous cause if I mess something up on the case it's not replaceable Since I got the case nearly 10 years ago I think.
    I'm going to be putting ( most likely ) ZOTAC's IONITX-A-U in it and watercooling it.
    -Concept now null-
    I've only got three layers of primer on the top panel done so far.*
    *at the time of the first post.
  2. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    good luck on the build!
  3. x_JesusNinja_x
    x_JesusNinja_x What's a Dremel?
    8 Mar 2009
    Good luck!
  4. ringo
    ringo What's a Dremel?
    14 Jun 2008
    I also wish you good luck on your project. Nice concept
  5. skreenname
    11 Jun 2009
    Thanks for the luck guys. :D
  6. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    AH verry nice, have one of these for a psp i wanted do a laptop out of. I'll be watching this!
  7. skreenname
    11 Jun 2009
    Link to the .Skp
    There's a concept for the watercooling.
    I'm thinking about 'embedding' a Koolance CHC-25-L06 into the stock heatsink.
    I got the Idea from Prometheus cu
    Also I've got some masking done on the case.
    But I forgot to sand/scratch it before I started taping everything up. Again.
    :wallbash:
    My cutting tool is a scalpel blade. I don't have a handle. :(
    And if anyone's interested Here's a video of my horrible technique.
  8. WolfandAngel
    WolfandAngel Got fins?
    2 Dec 2008
    do you mean Project: PrometheusCU
    Good luck:naughty:
  9. skreenname
    11 Jun 2009
    That's it!
    Thanks for showing me who it was.
    Now credit is given where it's due.
    :D
  10. skreenname
    11 Jun 2009
    I determined that I don't like the red of the RAM I have laying around and decided to try painting it.
    Taped up.
    Painted with flat black high-heat paint.
    Still some areas I need to touch up.
    Detail on the A-DATA logo.
    More taping on the case, I'm taking forever with this. I need to work faster.
    A shot of the side that was painted earlier.
    But for now I'm kind of stuck until I get another sharp utensil since I lost my scalpel blade.
    It was on my table when I left for the weekend, and when I got back it was gone.
    Dx
  11. WolfandAngel
    2 Dec 2008
    Paint the RAM white
  12. skreenname
    11 Jun 2009
    I'll check that out in sketchup and post the drawing.
    Edit:
  13. stonedsurd
    11 Mar 2009
    Awesome stuff! Subbed :D
  14. NightrainSrt4
    NightrainSrt4 What's a Dremel?
    25 Dec 2007
    Nice! I've got the same exact case lying around. Took out one of the dividers and put the psp in it a few years ago. Hasn't really been touched since. Glad to see someone trying something creative with it.
  15. skreenname
    11 Jun 2009
    With all the tape removed from the RAM, it looks quite nice.
    I know I missed a few spots, but it's my first time painting something with details like that, and I cut into the RAMsinks on accident when I was cutting the tape details.
    I think I did pretty well though.
    Note: the worst parts would be facing each other, and therefore not showing to the world.
    I'm still slowly, and I emphasize slowly, taping up the case.
    I'm down to the little bits and pieces.
    Just a few edges, the feet, two or three corners, and the latches.
    Also, once I get the first post there is going to be a poll for the color.
    I can't choose, so I need help.
  16. -dB-
    -dB- Unrestricted
    21 Feb 2008
    Next time, try applying a thin film of vasoline on the A-Data logo before you paint. after the paint is dry a cloth would remove the vaso and paint from the letters leaving them all shiney and pretty :)
  17. skreenname
    11 Jun 2009
    Thanks for the tip. :thumbsup:
    I was initially intent on having the logo shiny, but the black is growing on me.
    Though now that I think about it it might look slick if I cleaned off the A-Data logo.
    I should try on a 'in' side.
  18. pksjaveed
    pksjaveed Nmodz: modding the world
    28 Apr 2008
    he just take the clips off the ram and the heatsinks are held in by a little doublesided tape. soon and you take the clips off just slowly pull the heatsink off. i think that way you can get a better detail without worrying about getting it on the actual ram
  19. skreenname
    11 Jun 2009
    Okay, I just tried clearing off the paint from the A-data logo.
    It worked pretty well.
    Comparison:
    And my tool:
    A spoon with 320-ish grit sandpaper taped on to the handle.
    I really like the dark lines in the grooves.
    It reminds me of Lining a Gundam model.
  20. -dB-
    -dB- Unrestricted
    21 Feb 2008
    the all black look is definately more stealthy, shiney writing might stand out a bit too much depending on the look you are going for. good work using high temp paint :thumb:
    *edit* i guess shiney works then haha
