Graphics 460 GTX Overclock
Discussion in 'Hardware' started by iniquix, 13 Sep 2011.
  1. iniquix
    iniquix What's a Dremel?
    26 Aug 2007
    Good Evening,
    I've been working on over clocking my computer as of late and I'm looking to over clock my graphics card. I'm currently using GPU-Z to make sure Memory clock, shader etc is what it states it is and MSI Afterburner for the actual over clock.
    Currently I've been playing with the Core clock / Shader Clock and moving the Memory Clock up. I was wondering if this is the correct procedure for over clocking a graphics card or do I need to change the voltage?
    Current Graphics card Over clock is:
    Default: 715/1430 Mem: 1800
    Over clock: 830/1660 Mem: 2100
    Current Voltage for both is: 1012 and unchanged.
    Fan Speed at 70
  2. bulldogjeff
    2 Mar 2010
    To make life easy for you I've got my 460's set up as follows:
    Core; 812
    Shader: 1624
    Memory: 1912.
    This is a good solid over clock on air, but as mine are water cooled I can push a bit higher.
    I think these are pretty similar numbers to what Bit-Tech got when over clocking their test card.
  3. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Download Asus GPU Tweak... and adjust and test from within the tool in windows until you find a stable overclock.
    Test it with a combination of 3dMark 11 and Heaven benchmark. What will be stable in one may crash in the other.
    I used this app to tweak my mates SLI'd 460s. Worked a treat.
  4. mucgoo
    mucgoo Minimodder
    9 Dec 2010
  5. iniquix
    26 Aug 2007
    @ Sentinel-R1 any particular reason you'd choose that over MSI-Afterburner?
  6. Sentinel-R1
    13 Oct 2010
    It's got a bit more functionality bud and the next release will have the 'flash to bios' option once you've set your overclocks.... but obviously you need to ensure they're stable first. :)
  7. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    played mafia 2 all the way through on a 460.. with everything up even the physx scam on air.. was at 906 clk, think the mem was at 2150
    could do 847 stable stock volts.. the 906 was with a bios volt mod.. just good air, custom tim job and the stock cooler
