Graphics 460 SLI
Discussion in 'Hardware' started by boltonuk007, 31 Dec 2011.
  1. Teelzebub
    27 Nov 2009
    Never had a problem with SLI been using it for years it works great
    Apophis54 likes this.
  2. boltonuk007
    boltonuk007 What's a Dremel?
    29 Sep 2011
    ...and for £107.35 its a relatively cheap boost
  3. LennyRhys
    LennyRhys Oink!
    16 May 2011
    £107 is amazing for a new 1GB 460 - I paid nearly that for my second card, but it was used :eeek:
    The only problem I have with the EVGA is the crappy alumium cooler with no heatpipes. Quite a few of the 460s use these and whilst they are perfectly fine for single card use, they suck for SLI...
  4. boltonuk007
    29 Sep 2011
    just had to order an SLI bridge off ebay though for £5, I can live with that. I inherited the motherboard and it didnt come with one.
  5. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    I was sorely tempted to buy a cheap second 460 but as my first GV-N460OC-1GI is so good, i paid the extra £30 for another.
  6. boltonuk007
    29 Sep 2011
    I dont know how easy this is to judge but what do people think 2 x 460's are the equivalent of? maybe a 580?
  7. N17 dizzi
    23 Mar 2011
  8. N17 dizzi
    23 Mar 2011
    Where SLI 460s fall down over a 580 is at high res with lots of AA as the extra VRAM of the 580 gives it a good advantage.
  9. jizwizard
    jizwizard Modder
    24 Dec 2010
  10. boltonuk007
    29 Sep 2011
    thanks for that, thats a useful site, makes it quick and easy to make a comparison. I think its worth paying an extra £107 for the performance (ish) of a £350-£400 card
  11. jizwizard
    jizwizard Modder
    24 Dec 2010
    Definately
  12. N17 dizzi
    23 Mar 2011
    Yep, the numbers don't lie. SLI 460s are awesome for the price, albeit with a caveat or 2.
  13. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    It's worth overclocking the GTX 460 as well to catapult performance even further ahead of a GTX 580 in SLI enabled games. For example Battlefield 3 really benefits from SLI, not only is frame rate doubled compared to a single card but when overclocked; in my case to 890MHz on the core (with 1.112V) the game screams by on high settings at 1080P. Required a modification to the GPU BIOS to go over the 1.087V limit of the cards firmware but I'm reaping the rewards in game now!
  14. N17 dizzi
    23 Mar 2011
    IIRC Blogins you have a 2560 panel? How does BF3 run at native with your rig?
    I do not like the idea of lowering the resolution, I'd rather dial down other settings
  15. bulldogjeff
    2 Mar 2010
    I'm running SLI 460's and right now I can't see any reason to upgrade, there's nothing around they won't handle, like the others have said and overclocked they fly along.
  16. Blogins
    3 Aug 2010
    Personal preference. At native resolution I can get dips in frame rate down to 40FPS with high settings. At 1080P with high settings and vertical sync I get a solid 60FPS which makes me a better killer! :D
  17. boltonuk007
    29 Sep 2011
    i have my single overclocked to 900mhz, so two of these will be awesome!
  18. N17 dizzi
    23 Mar 2011
    I mainly fly jets in BF3 so solid 60fps not required for putting holes in choppers.
    You put holes in a different kind of chopper :D
  19. Blogins
    3 Aug 2010
    So many interesting tactics to use in Battlefield 3! :D
  20. boltonuk007
    29 Sep 2011
    I have a 550W PSU, do you think this will be enough? im getting all sorts of results from the online calculators.
