Embarking on Project O², I'm after a rather fussy waterblock design! Do you guys at AquaTuning stock a block compatible with the shorter HD4850? But the following requirements must be met: -Must be single slot (as in not impede on the slot directly below it -If it is not single slot it must be designed in such a way as it will let me use this sound card in the slot directly below the GPU: -Prefer the fittings to be facing down right at the top of the card so as to go through the gap available in the soundcard above This is going in a very tight fitting case! I did have a good look at the website but I can't find much in the way of 4850 blocks...
to be honest we dont tend to hold stock of blocks for the older lower end cards although it would be possible to order one in as a special or if EK still have some for example.
it's not low end! lol plays Left4Dead2 at full settings no sweat Ok I will have a nosy at the EK range and get back to you..
Haha, i know i didnt mean anything by it but what i mean is we tend to only stock the top of the range blocks for long periods of time. Let me know if it fits the bill and i can quote you for one.
