4870 trouble in Crysis
Discussion in 'Tech Support' started by Igniseus, 3 Jul 2008.
  1. Igniseus
    Igniseus What's a Dremel?
    5 Mar 2006
    Hi all.
    I'm having some trouble with my 4870 on Crysis. I'm running maxed settings except no AA, at 1920x1200. The same resolutions and setting nearly every review has. The problem is, they are getting from 27ish to 35 FPS, where as I am only getting about 22 tops, and as low as 18. Now if your thinking my other hardware, I'm running a Q6600 at 3.4GHz, 4GB of RAM at 902Mhz and Vista64; better than some of the reviewers systems. To further disprove that its a problem with other hardware, my 8800GTX used to get 26ish FPS, but in EVERY review, the 4870 beats it in Crysis.
    I've even tried overclocking 80Mhz core and 150/600Mhz memory and still the same.
    Also worth noting every other game is running almost exactly in line with the reviews scores.
    So, can anyone help me find my missing 6-12fps? :(
    Thanks
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Got the latest patch for Crysis?
  3. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    are the reviews you are looking at vista or winxp? xp would only be directx9 so that would make it faster.
    Just a thought.
    Also the sites that do reviews may have different drivers than the ones that are publically available. I'm sure someone from bit-tech could confirm (or unconfirm) that.
  4. Langer
    Langer Jesse Lang
    24 Jan 2004
  5. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    DX9/DX10 difference? Latest drivers? Reviewers may be using beta ones. Latest patches?
  6. Igniseus
    5 Mar 2006
    Latest patch, comparing DX10 only, using latest (only) drivers.
    Will try the mods thanks, though no doubt they used un-modded Crysis.
  7. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    Also try checking that you don't start up unnecessary services (they can bloat Vista quite badly)...
  8. Igniseus
    5 Mar 2006
    Good advice, but I'd rather not start messing with these. Besides, most reviewers will be running vanilla Vista SP1 most likely, and lets not forgot every other game I've tested is performing in-line with the reviews. Just seems to be Crysis being stupid :(
  9. BentAnat
    26 Jun 2008
    A lot of reviews also happen on fresh installs of Vista. So there's no bloated startup folders, no bloated registry, etc.
  10. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    I found considerable performance differences with the syncing of my CPU to my RAM. If its something really wacky it'll slow it down, if its synced (even with a odd ratio) it'll perform way better. Also if you dont have decent enough cooling your components may be overheating and causing issues. Get CPU-z to see what your ratio is, and then set your bios to sync. Then start to OC. There are countless Temp programs, but be sure your not in the 80-90c's with your CPU, that'll just cause more problems.
    Hope that helps. :)
